ERST Brake lines
ERST Brake lines
Hi guys,
I just changed the engine in my turbo, in doing this a snapped the brake joints from pumps to resevoir, so was going to change the abs back to non abs, but dont know if this possible?? reason im doing this is because the abs belts werent on car anyway or would I be better just getting abs pump second hand and put belts on?? any help would be great cheers
hi mate, was going to change system to non abs but dunno if be aswell with abs I would rather not have it, was going to take braking system of my series1 will this work on series 2 as it non abs? thanks
Not really sure mate.
I dont see why not. I removed the abs from my s2, pretty straight forwad job tbh, its been covered quite a bit if you search on the site.
As for using a S1 brake system, I dont see why it wouldnt work, as without the abs its only a reseviour and piping which is essentially the idea behind it.
The annoying ginger guy
hello m8 this is a peice of piss to do, i did it on my s2 cos mine got snapped off, just get hold of a brake flaring kit and some t peices, just run the lines from the front calipers to the back of the resivour and vice vercer, just make sure nothings kinked cos he very flimsy
