PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 29-03-2009, 05:36 PM   #1
cabbykarl
Trader Score: (0)
cabbykarl is an unknown quantity at this point
Send a message via ICQ to cabbykarl Send a message via MSN to cabbykarl
Default ZT Lots of oil coming out of breather pipe
Hi there, got an annoying problem with my freshly installed zetec turbo.
Now being a tight git (read skint) I fit it all myself into my Escort after buying the engine etc off Ebay. It's fitted with a rover inlet and erst exhaust.
1st problem I had to address was that the breather had been blocked off at the front and another put on the rear of the block. Now since my gearbox is a rear starter I blocked off the rear breather and welded on a nice pipe to the original front location.
This pipe i've then joined to the breather pipe coming from the head then it's a y-piece to a small k&n breather.
All was fine for a few days then it started what appeared to be steaming from the breather.
It wouldn't really matter how hot or cold then engine was either.
It would lose about a pint of oil each hour of driving and naturally's made a nice mess....
Anyone any ideas why this is happening?
I've stuck the breather pipe direct into a bottle and it's showed me just how much oil is coming out.
Perhaps the headgasket's failing as i've a slight water loss and the top rad pipe doesn't ever seem to get solid as it has done with previous engines.
Wont hurt me to do a compression test dry then wet I guess...
I'd be grateful for any ideas.
Thanks for reading,
Karl.
cabbykarl is offline   Reply With Quote
Old 05-04-2009, 12:21 AM   #2
cabbykarl
Trader Score: (0)
Well, changed the headgasket yesterday.
No change unfortunately.
It's a 15 mile trip back home from the garage I did it at and it's put about 3/4 of a litre into my oil catch bottle.
I don't get it as there's no smoke from the tailpipe, the actual pressure on tickover blowing out of the breather is pretty low but just lots of fumes and almost instant from cold too.
I'm stuck and thinking about getting rid as i've had enough.
Could ring wear show up as this? I thought if rings had gone it'd smoke loads...?
Karl.
Old 05-04-2009, 06:02 AM   #3
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
pa_sjo is an unknown quantity at this point
You'll find the original breather on the front was heavily baffled...
__________________
Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo.
pa_sjo is offline   Reply With Quote
Old 05-04-2009, 10:37 AM   #4
cabbykarl
Trader Score: (0)
Oh i see. Hmm off the top of your head got a suggestion as to what I might construct/fit to return the condensed oil back to the sump then?
Thanks for the reply btw
Old 05-04-2009, 10:26 PM   #5
siward
Trader Score: (0)
siward is an unknown quantity at this point
Send a message via MSN to siward
Have you done a compression test?, Sounds like crankcase compression which could be down to rings/piston, Is it breathing heavily from the top? or just the bottom breather?
__________________
siward is offline   Reply With Quote
Old 05-04-2009, 10:29 PM   #6
ob1marty
ob1marty's Avatar
Trader Score: (0)
ob1marty is on a distinguished road
there is a baffle plate in the block is that fitted do you know some people poke a screwdriver in back breather and it pushes it into the block sorry misread its a zetec not cvh sorry
ob1marty is offline   Reply With Quote
Old 13-03-2010, 08:41 AM   #7
cossieprob
550+ LUV IT!!!!!!!!!!!!!!
cossieprob's Avatar
Trader Score: (0)
cossieprob is on a distinguished road
I no this is an old post,, ,but my frst cvh engine,is spitting a lot of oil out of my breather cone on the top left pipe on the back of the rocker cover, when putting my foot down?
Its only just started doing it, the bottom end was rebuilt only a few k ago with new piston/rings etc etc,,, what can do this!!!????
CheeRS Rich
__________________
MSD Stage 3
member 42996
cossieprob is offline   Reply With Quote
Old 13-03-2010, 02:07 PM   #8
slydawg65
Trader Score: (0)
slydawg65 is on a distinguished road
CheeRS Rich
i'm having the same problem. can anyone shed some light on this???
slydawg65 is offline   Reply With Quote
Old 13-03-2010, 08:29 PM   #9
juffer
juffer's Avatar
Trader Score: (0)
juffer is an unknown quantity at this point
I had the same problem ans it was my breather (top left of the rocker cover). I put a new one on and it cured it. I think the filter or baffle inside had given up but i have not had any problems for 1000's of miles.
__________________
Ford cars and trucks - Powered by the past - Improved for the future
juffer is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
fiesta rs bailey oil breather, bottom pipe fitting problem? paceo General Car Related Discussion. 6 17-04-2008 11:29 AM
oil in boost pipe and oil coming out of dump valve jawanne General Car Related Discussion. 9 14-10-2007 02:01 PM
Zvh breather/oil return pipe union Roosie Ford RS Turbo parts for sale 2 31-07-2007 10:51 PM
fusion oil breather 4 pipe carlosl Technical help Q & A 0 25-06-2005 04:51 PM
oil coming from breather pipe need4speed Technical help Q & A 2 27-09-2003 08:34 PM
