PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 23-02-2009, 02:28 PM   #1
Cowboy24
Trader Score: (0)
Cowboy24 is on a distinguished road
Default Ford Sierra cvh 1.8 cam belt and timing issue
As we were driving home the other day the cambelt broke on my sierra. I checked the all the engine out and when i turn the engine over by hand all the pistons seem to move freely and there is no horrendous noises or anything. I have also checked under the rocker cover and all the valves seem to be moving freely as well. I have put a new cam belt on but when I try to start the engine it won't fire at all. I don't know if the engine is capput or the timing is just not right. Any advice any one could give would be greatly received.
Many thanks
Cowboy24 is offline   Reply With Quote
Old 29-01-2010, 03:44 PM   #2
jason73
Trader Score: (0)
jason73 is on a distinguished road
i have exactly the same problem with mine i no its the timing but cant find out how to do the timing myself so if you find out before me let me no ill do same
jason73 is offline   Reply With Quote
Old 30-01-2010, 12:21 AM   #3
martysmartie
Trader Score: (1)
martysmartie will become famous soon enoughmartysmartie will become famous soon enough
On CVH there are just two pulleys it goes around crankshaft and camshaft which is behind the dizzy, in fact the dizzy on these is no more than a rotor arm attached to end of camshaft. They are 36-1 as standard so what I would do line up missing tooth with CPS, then line up cam pulley (Do not know if this has any scribe marks to match up which simbolates TDC) More than likely you have bent at least one valve. But try this first and see, it may be you have it timed fine but as damaged valve you do not have compression.
Martin
martysmartie is offline   Reply With Quote
Old 30-01-2010, 12:29 AM   #4
turbocabessex
shit happens
Trader Score: (1)
turbocabessex is on a distinguished road
the cam pully has a little triangle bit in one of the holes which will line up to a mark on the head lookin through the whole, the crank will have mark on the lower aux pulley that will line up with a mark on the crank pulley cover or u can do this with the lower aux pulley off usin the crank pulley, it has a big washer behind it with a point stickin out line it up with a line on the crankcase these 2 atr tdc, get these right an tension it up, but check an double check its all still timed when tensioned
__________________
turbocabessex is offline   Reply With Quote
Old 30-01-2010, 07:12 PM   #5
Trader Score: (0)
tabetha will become famous soon enough
DON'T line up missing tooth with sensor as this will NOT be TDC, typically it will be 90 degrees, 1/4 turn BEFORE tdc, as it needs the missing tooth info before doing the maths, look instead as said for a mark on the crank pulley to line up with a mark on the cover somewhere.
tabetha is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
small turbo esccoss cam belt timing marks ??? 3drbadboy General Car Related Discussion. 11 09-03-2008 10:38 AM
Cam belt removal & timing Franco General Car Related Discussion. 41 12-06-2006 04:48 PM
Cam timing CVH mark-rst Technical help Q & A 6 13-03-2006 05:53 PM
cam belt timing cossie yogi General Car Related Discussion. 16 14-10-2004 01:30 PM
S2 chrome timing/cam belt covers Anonymous Ford Escort RS Turbo 2 10-03-2004 07:02 PM
