| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
No mate. The block on an RST has an oil return in the casting. You could modify your sump for this though. Main problem is your pistons are too weak, and give too high a compression. Do you know the mfi on a 3i is totally different from an RST?
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#3 |
OCD Victim
You can fit an oil-return into an XR3i block, well EFI anyway.
The EFI one has a casting blanked off which you simply drill out and insert the metal insert from the crankcase breather in the block (same insert). MFI may not have the casting which is big enough though. Have never checked.
__________________
"What is your major malfunction soldier?" Hi. This is the qmail-send program at kermit.axnoc.net. I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it didn't work out. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Free Xr3i bottom end | rst-s2 | Ford Non RS / XR / ST parts for sale. | 0 | 16-02-2009 07:15 PM |
| Free Xr3i bottom end | rst-s2 | Ford Escort RS Turbo | 0 | 16-02-2009 07:15 PM |
| my bottom end has gone in my xr3i | xr_triplow_turbo | Ford Mondeo (Including ST) | 9 | 19-12-2007 01:21 AM |
| RST Bottom end... | notSteveS2 | Ford Escort RS Turbo | 1 | 13-07-2006 07:52 PM |
| xr3i / rs turbo bottom end | davsmith64 | General Car Related Discussion. | 1 | 24-01-2006 04:17 PM |
