PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-02-2009, 01:02 AM   #1
escort_cab
Trader Score: (0)
escort_cab is on a distinguished road
Question 1.6 cvh head gasket change
I have recently bought a 1.6 cvh engine and before fitting it in my cabriolet i decided to see what condition the engine ''really'' is in.good job i did because head gasket was fooked and 1 of the head bolts was totally trashed.part of it had rotten away!!the pistons are pretty coked up,as is the underside of the head(valves)
does anyone know what causes the big ''coke'' up?(ALOT MORE THAN EXPECTED)and will i be ok with just cleaning the head and block for the new gasket or will i have to get either of them skimmed?
Thanks in advance
escort_cab is offline   Reply With Quote
Old 21-02-2009, 07:11 AM   #2
Trader Score: (0)
tabetha will become famous soon enough
As it's apart I would get both head and block skimmed, the head will defo need it, block would be a good idea.
The big coke up is just from burning petrol, releases carbon, plus you may well have more from worm stem seals though this is normally wet looking but bloody hard crystal like gunge.
Of more concern is the bolt hole, so ask a decent machine shop about this first.
tabetha is offline   Reply With Quote
Old 21-02-2009, 07:44 AM   #3
Lee Ivatt
Shizzle My Nizzle
Lee Ivatt's Avatar
Trader Score: (1)
Lee Ivatt is an unknown quantity at this point
Thanks in advance
Generally the block is ok 9 times out of 10. give it a clean, and a sanding with some fine paper with a FLAT/LEVEL sanding block, then lay a straight steel rule on it.
Areas to check are usually if theres evidence of blowing between bores at the tops.
If you in doubt at least get it checked buy your engineer.
As for the head, a reface/skim id a definate must. And whilst your at it you may as well have it pressure tested.
I had my 16i head done last monday. I have other work like multi angle seats etc but just skim and test cost £56.
A lot of people panic about skimming, but its not as bad as they make out. At the least it lowers your compression ration very slightly, which can offer more power. What the issue is, is it cam affect the cam timing.
Usually its not a big deal. a 0.50mm skim is about the norm.
And if you find its running a bit rough then simply adjust the timing a little, or fit a veneer pulley. but again this is only if it a tuned engine really.
Valves are about £7-9 each x8 so buy a new set of them, and lap them in.
Some new valve stems about £1.50 each x 8
Springs should be ok normally
check your hydro lifters, if they are pretty gummed up, may be worth getting new ones, again not that expensive.
Set if head bolts and a decent gasket.
Ive just posted this with lots of pics in my Rs1600i restoration thread, so take a look, if you need any advise then ask me or pleanty of other people on here will be happy to offer advise.
http://passionford.com/forum/restorations-rebuilds-and-projects/282583-black-rs1600i-project-restoration.html
Heads are relativly easy to do, should take you no more than an hour to strip (remember to lay out all parts in order. i use cardboard with a grid marked on it).
Anyone with a socket and spanner should be ablt to do this. Only tool you will need is a spring compressor. you can get a basic stem seal compressor for £10. this does the same job.
__________________
When all of your wishes are granted
Many of your dreams will be destroyed
Lee Ivatt is offline   Reply With Quote
Old 21-02-2009, 09:01 AM   #4
Trader Score: (0)
Actually skimming the head RAISES the CR, not lowers.
Old 21-02-2009, 10:41 PM   #5
escort_cab
Trader Score: (0)
Thanks lee .
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
1.6 cvh head gasket change rsvmad1 Technical help Q & A 8 21-08-2008 05:22 PM
1.8 cvh to rst head (what gasket))) b_kennedy Ford Escort RS Turbo 3 04-05-2008 11:35 AM
CVH head gasket szabyk RST Technical help Q & A 4 04-08-2006 01:48 PM
cvh sump gasket change w/o removing engine from car? andre_k General Car Related Discussion. 5 04-07-2005 04:47 PM
Cos head gasket change in N.E? plynchy General Car Related Discussion. 3 04-03-2005 07:41 PM
