cosworth mixture screw
RWD PUMA :)
hi
my little puma just squeezed through the mot ,the mixture was very high 4.9%
so i turned it down ,so it passed the mot but i went to turn it back up and wouldnt adjust?
then my co went to 7% and is stuck there now
so im looking for another ecu
or
information so that i can change the pot in my ecu ?
so has anybody ever done this ?
and what spec is the pot in the ecu ?
any help would be appriciated
thanks
or
thanks
Assuming you have a Weber Marelli L1 / L6 / L8 ecu, the CO pot only has 2 turns of + or - adjustment from its zero setting, if you turn it more than that it doesn't do anything. To get back to this setting, turn the screw 5 times in either direction, then turn it the opposite way 2 turns exactley, you now have upto 2 turns of adjustment in either direction.
RWD PUMA :)
its a L6
thanks for that
sounds a bit odd but ill give it a go ?
will i then get a reading if i measure the resistance?
or isit not possible to measure it?
thanks for that
That is correct, it will turn for as long as you can turn it, there is no stop for it. But it will only change the CO settings for upto 2 turns from zero, after that it wont adjust any more.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
