mk4 astra van engine manigment light flashing and won't start?
Old 30-12-2008, 05:44 PM
diesel
diesel's Avatar
Default mk4 astra van engine manigment light flashing and won't start?
as above i know nothing about vauxhall im a ford man plus iv never worked on a diesel if it was my erst i wouldn't have a problem coz that breaks down all the time iv spent more time fixing it than driving it
right then the van, i havent done any checks yet i thougth i would ask first, this is the newest car iv had so dont know much about engine manigment lights, i know there for sensors and stuff but thats about it.
does anyone have any experience with these vans or any idea what could be wrong, iv only had the van for 6 week and iv only opened the bonnet once to change the oil so i know nothing about about this engine.
any help would be great
Old 30-12-2008, 05:56 PM
900ss
RWD Racer
900ss's Avatar
What year and engine size?
if its a 2000 - 2003 mk4 1.7 diesel then ecu on the back of the pump are known for faults
Old 30-12-2008, 06:11 PM
diesel
diesel's Avatar
it's a mk4 diesel 1.7 dti van year 2000 w reg
Old 31-12-2008, 11:16 AM
900ss
RWD Racer
900ss's Avatar
Not sayin thats what wrong with yours, but its a good bet
http://ecu-testing.com/vauxhall_astr...i_tdi_isu.html
http://www.ilexa.co.uk/forum/index.p...ic,6772.0.html
You can pick them up for £60 used
Old 31-12-2008, 01:46 PM
Phil2002
Phil2002's Avatar
if the engine managment light is flashing it may be to do with the chip inside the key for the immobiliser try all the spare keys you have for it. Also if you have a multimeter put it on the battery and make sure it does not drop below 10.5v if it does your battery is causing the problem as the ecu will shut down if the battery does drop below 10.5v.
Cheers,
Phil
Old 31-12-2008, 04:00 PM
diesel
diesel's Avatar
thanks both it seems like it's an imobiliser problem i been on a vauxhall forum and said the same, and thay seem to think it's the imobiliser as well. thay said if it's flashing, thats the imobiliser, if it was the engine manigment it would stay on all the time.
thanks for your replys
Old 31-12-2008, 04:09 PM
Phil2002
Phil2002's Avatar
The ecu controls the immobiliser and will still flash the light if the battery voltage is too low. The light will only be on permenatly if there is a problem with an engine sensor. check round the ignition barrel it should have a black plastic ring around it this is the reader coil for the ecu to read the chip make sure it has not been damaged. it is unlikely the ecu has forgotten your keys as they use non-volitile memory so they don't forget the keys if the battery is disconnected.
if you've got another car there stick some jump leads on it and then try and start it if not take the battery off and charge it upover night.
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
track.focus'd
12-08-2015 05:53 PM
Sjieter
05-08-2015 09:47 PM
vdubo7
02-08-2015 08:17 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: mk4 astra van engine manigment light flashing and won't start?
