PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-12-2008, 06:32 PM   #1
Steve Rst
Trader Score: (0)
Steve Rst is an unknown quantity at this point
Default Removing the alarm/immobiliser part of a zetec loom?
As title really
I have a 2.0l zetec engine from a 2000 x reg focus.
I'm fitting it into something else, and want to use the original ecu/loom for the moment to get it up and running.
I have the key, transponder etc, but i dont want to use the alarm/immobiliser.
If i split the loom, do i have to fool the ecu into thinking the alarm is there? or can i just cut it out?
cheers for any help
Obviously this is info that may not want to go into the public domain for peoples car security, so if someone could pm the answer that would be great.
__________________
Better to keep your mouth shut and appear stupid, than open it and remove all doubt.
Steve Rst is offline   Reply With Quote
Old 24-12-2008, 04:49 PM   #2
Steve Rst
Trader Score: (0)
bump
__________________
Old 24-12-2008, 04:59 PM   #3
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
pa_sjo is an unknown quantity at this point
The immobilisor is inside the ECU, so no.
__________________
Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo.
pa_sjo is offline   Reply With Quote
Old 24-12-2008, 08:12 PM   #4
Steve Rst
Trader Score: (0)
so whats the black box all about then?
__________________
Old 24-12-2008, 08:15 PM   #5
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
Trader Score: (0)
clarke5700 is on a distinguished road
Send a message via MSN to clarke5700
probaly the transponder unit
__________________
" im special,, excuse my spellings"
clarke5700 is offline   Reply With Quote
Old 24-12-2008, 10:33 PM   #6
westus1
westus1's Avatar
Trader Score: (6)
westus1 is an unknown quantity at this point
you cant cut it out, its through the ecu
unless you've got an aftermarket 1 fitted as well
but you cant do away with the chip'd key
westus1 is offline   Reply With Quote
Old 24-12-2008, 10:34 PM   #7
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
An alternative would be to use a very early 2L Mondeo ECU and loom. Something circa 1993. They ran an external PATS unit which you can bypass by bridging a couple of wires.
__________________
Old 25-12-2008, 02:44 AM   #8
Trader Score: (0)
tabetha will become famous soon enough
AS above the external pats ones on the early cars up to 96 only need one wire cutting out and bridging, they only cut the ignition feed.
tabetha is offline   Reply With Quote
Old 26-12-2008, 08:43 AM   #9
Steve Rst
Trader Score: (0)
ive got the key and transponder ready, so i'll just have to wire that all in then.
cheers
steve
__________________
Old 15-05-2009, 09:39 AM   #10
mgb
Trader Score: (0)
mgb is on a distinguished road
Default Removing immobiliser
I have the same problem but on a '99 Focus 2Ltr Zetec. The loom I have stopped at the connector on the A Post which I have now removed.
I can't find any details for the wiring of the key transponder, does anyone know which pins on the ECU the transponder wires should be connected to?
mgb is offline   Reply With Quote
Old 16-05-2009, 09:17 AM   #11
JonathanJ
Trader Score: (0)
JonathanJ is on a distinguished road
Easiest way is to go to maplins and get a black plastic box , get the key and the pickup ring and place in box and then hide box up the back of the dash , or just tape key and ring together up back of dash and use your normal key to energise ignition circuit , quick esay and saves a lot of hassle
JonathanJ is offline   Reply With Quote
Old 16-05-2009, 09:57 PM   #12
mgb
Trader Score: (0)
Thanks Jonathan, the problem is that I don't have the wiring between the transponder and the ECU and therefore do not know which connections to make
Mike
Old 11-06-2009, 09:43 PM   #13
PerS
Trader Score: (0)
PerS is on a distinguished road
mgb
If you have got an ECU with 104 pins:
No 1 on the transponder to +
No 2 to ground
No 3 to pin 19 on ECU
No 4 to pin 53 on ECU
Per
PerS is offline   Reply With Quote
Old 11-06-2009, 10:45 PM   #14
mgb
Trader Score: (0)
Thanks Per
Unfortunately, mine is a 60 pin ECU
Mike
Old 13-06-2009, 09:15 AM   #15
PerS
Trader Score: (0)
60 pin ECU (EEC V):
No 2 to ground
No 3 to pin 38 on ECU
No 4 to pin 5 on ECU
Per
Old 16-06-2009, 10:08 PM   #16
mgb
Trader Score: (0)
Thanks Per - that is excellent.
Is there a convention when numbering the pins on the PATS unit, it does not have any numbers on it
Mike
Old 17-06-2009, 06:38 PM   #17
PerS
Trader Score: (0)
mgb
Send me a PM with you e-mail adress and I will send you a picture with the pin numbering.
Per
Old 11-08-2009, 11:10 PM   #18
gklhso
Trader Score: (0)
gklhso is on a distinguished road
perS, from your replies i noticed that you do know what you are talkin about, so i have a question, I have a mk2 mondeo 1.6 and i put a 2.0 silvertop in, unfortunately my car has an EEC-V 104 pin ECU, so how can i fit the old DEEP DESK or DEWY non pats ECU's???
gklhso is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
1991/2 XR4x4 alarm/immobiliser Iain Mac Technical help Q & A 0 02-10-2008 09:35 PM
Whats best Alarm/Immobiliser???????? James90RS General Car Related Discussion. 0 08-04-2006 09:36 PM
Standard Alarm & immobiliser kevbo Ford Escort RS Cosworth 3 01-02-2006 09:46 PM
Immobiliser/Alarm Problem aldy Ford Escort RS Turbo 4 05-01-2006 11:36 PM
any info on factory immobiliser alarm 4x4 cossie NAKRS Ford Sierra / Sapphire / RS500 Cosworth 4 20-09-2004 09:41 PM
