Using megajolt for 1.6 cvh
Old 10-06-2008, 03:31 PM
javierant3
javierant3's Avatar
Default Using megajolt for 1.6 cvh
Hello, I am planning to change my actual distributor ignition for a megajolt system.
I know that I need a full E-dis 4 from another car, but because my flywheel hasn`t marks for the cps, what can I do to mount the Cps. I think I can mount a toothed wheel on my crankshaft pulley. Is there any economical method to fit that?. And also where can I buy the megajolt box?
The engine is modified with twin 40`s and a newman phase 1 cam, with slight work in the head, and MFI exhaust manifold.
Old 10-06-2008, 05:20 PM
fonfe
fonfe's Avatar
megajolt you can buy off ebay for around £70, if you email the bloke he can give you all the info regarding on how to use/set it up as i spoke to him 6 months ago as i was planning on using megajolt.
Old 10-06-2008, 07:08 PM
Pob
Pob's Avatar
There is a link to the forums,
To the page where you buy the megajolt and a
Page that tells you know how/info how to set up.
http://www.autosportlabs.net/index.p..._Users_Welcome
I'm going to be running carbs on a zetec, I can't help in a anyway in regards to a cvh. Sorry. Some of the guys on here/their may help.
I think i've seen a guy on the forums running a rs turbo cvh?
Good luck.
Old 11-06-2008, 04:08 PM
Rick
Rick's Avatar
1800 CVH pulley and CPS.
Old 12-06-2008, 09:48 AM
javierant3
javierant3's Avatar
Okay , thanks for the responses. I Want to mount 1800cvh pulley an cps, but here in Spain, there isn`t very sierras in the scapyards, and that is difficult to get.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
mondeomark
28-09-2015 06:28 AM
sridgett
13
27-09-2015 06:03 PM
focuspower
20-09-2015 03:51 AM
Quick Reply: Using megajolt for 1.6 cvh
