PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 01-02-2004, 09:16 AM   #1
alan rainbow
alan rainbow's Avatar
Trader Score: (0)
alan rainbow is an unknown quantity at this point
Default secs monitor volt reading
with the ignition on but not running secs reads 12,6 volts then when i run engine it reads about 13 volts but if fans come on and lights on it drops as low has 10.8 some times is this normal
__________________
tuned and mapped by www.norrismotorsport.co.uk
alan rainbow is offline   Reply With Quote
Old 01-02-2004, 07:20 PM   #2
Trader Score: (0)
Anonymous is an unknown quantity at this point
Absolutly no.
When engine running, you should obtain 13.8 volts.
I think you have alternator charging pb.
Anonymous is offline   Reply With Quote
Old 02-02-2004, 06:59 AM   #3
Trader Score: (0)
I had a similar problem - alternator was really low volts. Change the voltage regulator thingy on the alternator itself - it worked for me.
Old 02-02-2004, 06:14 PM   #4
3door
Trader Score: (0)
3door is an unknown quantity at this point
when running 13.7-13.8 is about right but if u are at idle the voltage will drop slightly depending what load u are running eg lights fans stereo
3door is offline   Reply With Quote
Old 02-02-2004, 07:40 PM   #5
alan rainbow
Trader Score: (0)
sorted cleaned all the connections on the battry and it now idles at 13.8 volts switched every thing on and still running 12 volts
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
