Discussion on Cossie understeer and Rear Beams (title edited
#82
Mike do you have bump steer and camber change details for your beam? or an Ahmed beam? Also has Michael call you regarding sending something to me?
#83
Caraholic
Rear bumpsteer:
Bump
60mm - 0.030" toe in
50mm - 0.023" toe in
40mm - 0.015" toe in
30mm - 0.009" toe in
20mm - 0.005" toe in
10mm - 0.003" toe in
0.0mm - 0.000" toe in
Droop
10mm - 0.001" toe out
20mm - 0.002" toe out
30mm - 0.003" toe out
Yes he has, I have to visually inspect it tonight.
#84
Rear bumpsteer:
Bump
Droop
#87
Caraholic
Didn't measure that, sorry.
Zero is the static ride height as I had the car set up to. I don't know if it was equivalent to standard, as I had 235/40 x17 tyres on, with the car set to a slightly "bum-up" stance.
FYI these measurements were taken on my Sapphire when Chris Woods set it up. He prefers static parrallel, as this gives a small amount of toe-out when moving forward. This makes the car a little nervous (and needs constant steering inputs), but it really did turn-in superbly.
On my Escort, I set the static toe to be in (0' 20"), as I didn't need the turn-in to be so aggressive with the shorter wheel-base.
#89
Hey Mike
Managed to get round to fixing the adjustable TCAs, and the freshly refurbed 3 door hubs! All went together quite easily
I havent had chance to set up properly yet (what with there being no engine in the car).
So given that we are setting up for the nurburgring, I was going to set the Camber to 2 deg neg, but how about the track?
JJ
JJ
#90
Originally Posted by MATCOS
Mike,
how much are the Ahmed rear beams, do you know?
#91
Caraholic
Originally Posted by JjCoDeX75
Hey Mike
JJ
JJ
#92
Caraholic
Mike,
#93
#95
Have you opened the Ohlins box yet - post some decent pics up .
I'll post pics later
#96
Mike - when you say 2 deg to the rear - I assume that you mean the TCA's?
I havent put the adjustable rear beam on yet what with me having not bought it yet.
JJ
JJ
#98
Caraholic
JJ
JJ
#99
JJ
JJ
Camber Angle
This should be set to -2 degrees (so negative camber from vertical of 2 degrees).
Toe In
What is this set to - presumably factory standard?
Castor Angle
No adjustment made to this...?
Leave the rear alone till I fund the rear beam
JJ
#100
Escort rear antiroll bar is gonna be fun to find!
JJ
JJ
Get the complete set with bushes and the holders for the bushes as its a different diameter and the holders are made a bit sturdier than the sapph ones.
#101
Caraholic
All your diagrams are correct.
Toe is subjective - running it parrallel on a Cossie makes them "nervous" and prone to following every bump etc in the road.
I prefer a small amount of static toe-in (2mm front 3mm rear).
The only way to adjust the castor is eccentric top mounts or shimming the ARB. On my Escort I run 3° 30" as per the Grp A tarmac settings.
As I said, handling and preferred turn-in is subjective. You need to set the car up to YOUR driving style, which will require some experimentation.
#105
Originally Posted by Stavros
Oh my god, soon cossies may handle
#106
#109
#111
Will the beam be fully adjustable?
JJ
#112
#116
UNAUTHORISED DEVELOPMENTS
I've got the complete front and rear suspension setup from nigel worswick's saph 4x4 rally car,which is basically 909 coilovers,tca's,tension struts,unknown roise jointed rear beam,rear diff cover with integral body mounting etc. all solid mounted.
This will be fitted to a saph or mk2 5 door,but with a ford v8.
Does the cars weight affect setup,as in ,the front end will be heavier than if a yb was in there.
Do any grp a settings apply on this setup? If so where do i get them from?
