1.25 engine swap to 1.6 zetec s problems
hi peeps, just in the process of swapping engines, its a 1999 fiesta 1.25 and the engine blew so i have got a zetec s 1.6 from a w reg 2000 car the wiring loom that came with the car does not plug into my car as the plugs are all diff???? can i use the 1.25 loom with the 1.6 ecu, chip and key???? or am i gunna have th rewire the 1.6 engine loom with the plugs off the 1.25 loom??? if anyone can help me i would really apreciate as this is driving me round the bend!!!!!!!!! cheers
so how do i wire the 1.6 loom up though with the plugs being diff? got both looms just need to make one work........... help this is really annoying problem
the only differance is the shapes of the plugs at the box may be mod those and dont forget the ecu ivery simple as iv done many before pls contact me if you need more help ???????/
JoeyBoyden
04-01-2024 02:36 PM
