Cosworth parts, Siemens 55lb injectors, RS500 cooler etc *PRICES REDUCED*
All sold parts deleted
Siemens black 55lb injectors, just flow checked - £185
Radtec RS500 intercooler - £210
Standard rad and fans - £65
Standard rad - think it has a small leak - £30
Bailey header tank - £85
Bailey breather (big one) - £65
K&N cone filter, in used condition, with trumpet - £40 posted
2wd fuel rail and regulator - £25 posted
2wd inlet manifold crackleblack'd - £50 posted
Standard coil, in stainless bracket - £12 posted
Complete 2wd inlet manifold - £25 posted
Turbo oil feed pipe - £15 posted
Sorry guys i wrote it all out with prices, then lost it and had to re-write it
engine loom is 2wd in very good condition indeed, not original injector plugs £70
black leads £20
blue motorsport leads, only 200miles use - incorrect diagnosis of fault! £65
air filter heatshield - £25
will reply to all PM's when i'm back on a PC
black leads £20
In the next couple of weeks, there will also be
-Twin amps on bracket
-Coil pack on bracket
-L8 ECU converted to run coilpack
-Ryan wiring loom, for coil pack/wasted spark and closed loop
-MSD chip for T34 .63 and 55lb blacks, with ALS & LC
-55lb Siemens black injectors
-T34 .63 been fully rebuild in Jan 2010, done approx 200 miles
Bit of an odd minor request - I need 1x mint front track control arm outer ball joint rubber seal, with spring clips?
Potentially lots of work for little gain I appreciate, but I'm in dire need.
Price and postage to Crewe area?
Thanks,
Alex
Thanks,
Alex
