sierra cosworth odds and ends
i have some used cossie odds and ends,4x4 starter motor.working fine when removed,could do with a lick of paint,£20.4x4 front anti roll bar,£15.4x4 ford track control arms,3 of,all have the big balljoint as opposed to the pattern tcas,£offers.ford anti roll bar to tca rubber bushes,4 of brand new and unused,£offers.4x4 and 2wd rear hub flanges and splined spigots?the stubs that go through the hub at the end of the shaft and hold the whole lot together with a nut,£20.almost new 4x4 brake servo assembly and abs block,this is the whole thing as you would remove it from the car and the block that sits on the n/s inner wing,like new condition,£offers.rear 2wd metal boot badges,used and a bit worn,£10.
i also have boost and water hoses,all standard,2wd intercooler air deflector plate,1 rear window seal in good nick,no bubbling and a washer bottle.i have put offers above as i dont know what the parts are worth.all prices are + postage.
charliecosworth
19-08-2015 02:00 PM
14-08-2015 11:21 AM
