Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) All Ford rs parts for sale in here that do not fit in the popular Cosworth or Cvh turbo sections. Starting a topic requires you to have purchased a gold membership.
aeroquip hose, rs1600i rocker cover, zvh plate
Old 22-04-2009, 06:12 PM
xrsi
xrsi's Avatar
Default aeroquip hose, rs1600i rocker cover, zvh plate
right i have got a few bits i could do with clearing to free up some funds to finish the fiesta off....
will keep adding bits as and when i find them but here's the list for now.
Aeroquip -6PTFE fuel hose
2 x 2.5mtr lengths (5mtrs total) of aeroquip -6 PTFE lined fuel hose, forgot i had a 2.5 mtr length and then brought 6 mtrs from thinkauto to do through the car at £10 per mtr!!!
This hose is high pressure and the correct bore for both feed and return and being PTFE lined will not breath vapor into the car. this is more than enough to do front to back of a fiesta or escort!!!!
am looking for £25 plus postage.
genuine ford CVH motorsport alloy rocker cover with correct oil filler cap.
Great condition as origionally fitted to the RS1600i free from cracks or warping and comes with the correct filler cap for the oi which is very hard to come hold of as they have been lost or broken.
Has had the vacume for the carb blocked with weld and then the 1/2" push fit breathers changed for -8 aeroquip weld on fittins to run aeroqip hose.
Am after £65 plus postage.
ZVH water pump adaptor plate
ZVH waterpump adaptor plate to run a CVH water pump on a zetec bottom end complete with gasket, never used.
£10 posted!
Old 06-05-2009, 07:26 PM
stevos1
stevos1's Avatar
would you sell the rocker cap seperate?
Old 08-05-2009, 04:31 PM
xrsi
xrsi's Avatar
no
Old 10-05-2009, 08:01 PM
B1G_RST
B1G_RST's Avatar
pm me lowest for the rocker posted cheers
Old 10-05-2009, 09:33 PM
Puss2
Formerly know as Puss
Puss2's Avatar
Where abouts are you?
Old 10-05-2009, 09:56 PM
xrsi
xrsi's Avatar
oswestry shropshire
hose and cover sold
Old 11-05-2009, 08:40 PM
Puss2
Puss2's Avatar
Bugger
Chas
05-10-2015 07:13 PM
IainRS1700T
25-09-2015 06:44 AM
timsrs
22
24-09-2015 08:14 PM
Brickhouse
23-09-2015 06:28 AM
davidfordrs
21-09-2015 04:23 AM
Quick Reply: aeroquip hose, rs1600i rocker cover, zvh plate
