Focus RS 324mm rotor/bell upgrade kits
Focus RS 2.0l Rotor & alloy bell upgrade kit - Special Offer £525
Massive unsprung weight savings of 4.5kg per disc (9kg in total)
Angled curved vane vented racing rotors, designed to run cooler longer, cast with angled groove face vents, stress relieved heat treated and finished to tolerances approcahing 0.010mm
50 micron hard annodised black HE30 alloy bells, fixed with specially treated destressed and plated bolts with heat resistant cleave nuts.
324 x 28mm direct fit straight swap
Ongoing costs are much cheaper than replacing standard discs !!
For subsequant purchaces you will only need to replace the rotors at around £140-£150 each. Bells compatable with most euro/USA spec rotors.
Be aware of far eastern upgrades that use non standardised PCD bells and offsets that tie you into their products for life !!
Manufactured to ISO9000 spec and built supplied from the UK
jonfoc
16
11-09-2018 05:35 PM
09-03-2016 01:03 PM
03-11-2015 04:08 PM
