Various cosworth parts
As title will be clearing space so i have the following for sale:
4x4 front anti roll bar £10
4x4 Drivers side hub needs a wheel bearing (supplied) £50
Complete set of front and back 3 dr brakes with drilled and grooved discs, backs look nearly new and fronts were refurbed recently £200
Spec R Small turbo cambelt cover £85
Group A coil brand new £20
Twin ignition amp bracket in black £30
Escos nomad a pillar pod for 52mm gauge (as new) £35
Rs 4 spoke wheel, ok condition but no boss £50
Pace turbo cooler £50 SOLD
2wd stainless exhaust no front pipe / tatty £30
T34 turbo needs a rebuild, 48 housing £150
Hoses - lots from standard to silicone -offers
2wd gearbox £250 SOLD
2wd inlet £15 each ( i have 2) BOTH SOLD
2wd Exhaust manifold (both parts) £50
Complete 2wd engine - needs rings offers
2wd loom, not the best £25
2wd loom £50
L1 ecu - untested £30
Set of dark green injectors £100 SOLD
L6 ecu with stage 3 chip £60 SOLD
2wd turbo heatshield, cracked lower down - £25 SOLD
Will add more parts as i go.
I can be contacted on 07725238098.
Regards Steve
2wd loom £50
Regards Steve
3dr cossie
11
21-12-2015 03:38 PM
14-08-2015 11:21 AM
