Metal Clutch Quadrants
Old 31-07-2007, 08:17 PM
dave_y
dave_y's Avatar
Default Metal Clutch Quadrants
How many people want one as there has to be a decent amount of people interested before the company I have contacted deem it worth while to make them. Ball park cost is £20 each.
Old 31-07-2007, 09:12 PM
Micky
Micky's Avatar
yes please,put up a photo so we can see the quality.Regards,Micky
Old 31-07-2007, 09:23 PM
1.9 xr2 on 40's
st170 breaking
1.9 xr2 on 40's's Avatar
doubt he can put a pic up if the co wants a certain amount to start makin em
once 1 is made they will most likerly have the prog done to remake loads
its the 1's job thats the time/work
Old 31-07-2007, 09:27 PM
Bryan_RST
Bryan_RST's Avatar
yes i am in how long would it take thanks bryan
Old 31-07-2007, 09:35 PM
dave_y
dave_y's Avatar
thats correct, i don't have one yet.
they are going to be good quality though, being designed on computers and everything aparently...
just trying to see how many people would actually want one.
Bryan_RST about 2 weeks hopefully.
Old 31-07-2007, 10:03 PM
GraphiteGray
GraphiteGray's Avatar
I'd be interested is it going to be a exact copy of the original quadrant or will it be like the modified one that AP recommends? the reason i ask is that with the quadrant as it is the pedal was way too high on mine so i had to do the AP mod
Hope you know what im talking about
Old 31-07-2007, 10:23 PM
dave_y
dave_y's Avatar
will be an exact replica of a quadrant which has been modified to AP Racing spec.
Old 31-07-2007, 10:28 PM
MarkXr
MarkXr's Avatar
I want one. 20 Pounds sounds good. I'm afraid the shipping will cost me more. By the way are you willing to take care of that for me as I live in The Netherlands?
Maybe a good idea to make a list in this topic with peoples who like to order one. Everybody who wants to order as well just copys the list and adds his own name to it.
I'll also post a link to this topic in our previous broken quadrant topic to reach the people that might be following that.
Here it goes: (Micky didn't add your name to it because you wanted to see the quality. Please correct me if I'm wrong by adding your name to the list)
1: Bryan_RST
2: MarkXr
3: ??
Old 31-07-2007, 10:31 PM
dave_y
dave_y's Avatar
yeah sure will post it for you
1: Bryan_RST
2: MarkXr
3: Dave_y
Old 31-07-2007, 10:45 PM
SafeChav
SafeChav's Avatar
So this is going to be a mk5 quadrant less the 10 or so teeth's worth AP say to chop off?
Old 31-07-2007, 10:55 PM
dave_y
dave_y's Avatar
Yup thats right. I made a quadrant up specially for them but will probably get them to make a copy of the one that is in my car at the moment as its tried and tested.
Old 31-07-2007, 10:58 PM
sm
sm's Avatar
put me down for one
Old 31-07-2007, 11:01 PM
SafeChav
SafeChav's Avatar
dave you can give me a free one for all the help i give you on MSN
Old 31-07-2007, 11:06 PM
dave_y
dave_y's Avatar
SafeChav you can have a pound off!
Old 31-07-2007, 11:07 PM
SafeChav
SafeChav's Avatar
a fucking pound
Tight cunt
Its a pound a word next time on msn
Old 31-07-2007, 11:08 PM
s1kid
s1kid's Avatar
Id probs put my name down
Old 31-07-2007, 11:40 PM
Rick
Rick's Avatar
How many people have managed to brake the ford one?!
I would bet good money that few cars have as heavy a clutch as mine, and get used so much in stop start traffic. The one i have was fitted over 6 years ago and is still going strong!
Old 01-08-2007, 12:49 AM
Micky
Micky's Avatar
OK,Dave y Im very interested in one and believe you when you say its top quality.It will be based on a modified quadrant you have supplied,yes???Can I ask you is this modified as per AP's website???Because I personally found that this mod makes the pedal sit way too high.I myself use a standard Mark 4 RST quadrant with the Mark 5 pedal,which when the bolt on the pedal is tightened up sit's at the perfect level,ie.. in line with the brake pedal.Sorry for all the questions,but Im sure you recognise all the different varients that have been mentioned on this Mark 5 pedal debate over the past few months.Best regards,Micky.
Old 01-08-2007, 08:25 AM
MarkXr
MarkXr's Avatar
Micky, when using the Mk4 quadrant the mod won't be of any help in disengaging the clutch any better over the standard Mk4 pedal setup. The cable travel is bigger because of the Mk5 quadrant has a larger diameter. For a strange reason some cars NEED the larger diameter and some don't. When Dave makes up metal quadrants with the small Mk4 diameter a lot of people can't use it.
If you mount a Mk5 quadrant with 10 teeth chopped of the pedal can be adjusted in height with the bolt. The bolt isn't supposed to be tightened up, it's for adjustment. This way you can set the pedal at the exact height you want. Best to set it a tiny bit higher then the brake pedal.
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: ??
Old 01-08-2007, 09:11 AM
Alex_86
Alex_86's Avatar
i may order one
Old 01-08-2007, 10:09 AM
MarkXr
MarkXr's Avatar
Then add your name to the list if you do.....
Old 01-08-2007, 11:02 AM
SafeChav
SafeChav's Avatar
But who's saying micky hasn't done it for the reliability side of it?
No teeth to strip this way!!
Old 01-08-2007, 11:58 AM
MarkXr
MarkXr's Avatar
I'm not saying that it's wrong how he has done it. But it wouldn't help those people who need the larger diameter. It's the larger diameter that is recommended by AP and many of the AP clutches seem not to disengage properly with the standard diameter.
Old 01-08-2007, 12:57 PM
Benxrrst
Benxrrst's Avatar
Default Clutch Problems
Can anybody shed some lght on this i have a s2 and have an AP clutch fitted and it bites really low to the floor and the peddle is slack could one of these quadrant cure it? or would i need the mk 5 conversion?
Old 01-08-2007, 02:55 PM
Alex_86
Alex_86's Avatar
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
what is the weight on it?
Old 01-08-2007, 03:38 PM
Marc LJX
Marc LJX's Avatar
How many would they have to make for the price to be £20?
Old 01-08-2007, 05:50 PM
Micky
Micky's Avatar
[quote="Alex_86"]1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6.Micky
quote]
I'll take one,its only €30/£20!!!
Now about my set up.I have typed about this problem at lenght on the other thread all about quadrant failure.My clutch DID'NT disengauge with a Mk 4 pedal and MK4 quadrant,DID disengauge with a MK 5 pedal and modified(10 teeth cut off the end) Mk 5 quadrant,BUT the pedal sat miles too high.And that was with no frigging bolt in the pedal,if I fitted and turned the bolt the pedal went even higher!! So I now use a MK5 pedal with a MK4 quadrant and it works perfect AND sits at the correct height!!!So thats why I asked Dave y what quadrant is been used for the pattern,Im guessing MK 5 modified???So my next question is,how high will the clutch pedal sit????Regards,Micky
Old 01-08-2007, 07:15 PM
sykes
sykes's Avatar
count me in defo!! Ju done my pedal and can' be arse with keep on taking the box in and out!!
Old 01-08-2007, 09:02 PM
GraphiteGray
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6.Micky
7.Graphitegray
Put me down for one if these get made, hopefully it'll be the last time that i'll have to squeeze under the dash upside down fiddling with bushes and washers
Old 01-08-2007, 09:28 PM
MarkXr
MarkXr's Avatar
That's strange. I've done the AP mod as the AP website describes and the pedal can be adjusted perfectly with the bolt. With bolt almost out the pedal is on the floor and I can set it as high as I want. Works perfectly except for the snapping part.
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: ??
Old 01-08-2007, 11:32 PM
SafeChav
SafeChav's Avatar
[quote="Micky"]
Originally Posted by Alex_86
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6.Micky
quote]
Thats very odd!!
Daves ones will be the mk5 ones im 99.9% sure. If your pedal sits too high, try using a shorter bolt, as thats what pushes the quadrant to adjust
Old 02-08-2007, 12:23 PM
sm
sm's Avatar
im running the mk5 pedal and quadrant modded as per the ap website and i can adjust mine so the clutch pedal sits level with the brake pedal and still engages gears fine, ive only done 200 miles since fitting it so im waiting for the quadrant to snap everytime i change gear
Old 02-08-2007, 12:24 PM
s1kid
s1kid's Avatar
Count me in guys
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: ??
10:s1kid
Old 03-08-2007, 05:14 PM
Moose
Moose's Avatar
put me down for one
Old 03-08-2007, 05:26 PM
MarkXr
MarkXr's Avatar
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: s1kid
10: Moose
Old 03-08-2007, 06:53 PM
dave_y
dave_y's Avatar
i use the parts as listed by the part numbers as per AP Racing website.
Old 04-08-2007, 08:39 PM
SWITCHBLADE
Passionate about fords
SWITCHBLADE's Avatar
sign me up
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: s1kid
10: Moose
11: switchblade
Old 05-08-2007, 01:49 PM
Chris69
Chris69's Avatar
just make sure it is a cut down quadrant as per ap's site- i had one made up that was almost a half moon so to speak and the pedal sat far too high even with the bolt fully out.
i ground some off and now its about right-feels alot more solid aswell
Old 05-08-2007, 03:54 PM
R6Franky
R6Franky's Avatar
sign me up
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: s1kid
10: Moose
11: switchblade
12:R6Franky
Thats £240 worth of business so far. How many more is needed before we find out if this will be done and given a delivery date.
Dan
Old 05-08-2007, 04:19 PM
JimmyBoy
JimmyBoy's Avatar
Add me
1: Bryan_RST
2: MarkXr
3: Dave_y
4: sm
5: Alex_86
6: Micky
7: Graphitegray
8: sykes
9: s1kid
10: Moose
11: switchblade
12: R6Franky
13: JimmyBoy
Quick Reply: Metal Clutch Quadrants
