PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 02-03-2007, 07:35 PM   #41
se mk3 cabbie
se mk3 cabbie's Avatar
Trader Score: (0)
se mk3 cabbie is an unknown quantity at this point
Nice to see another cabbie being saved, good work fella
__________________
se mk3 cabbie is offline   Reply With Quote
Old 05-03-2007, 09:50 PM   #42
cabrio boy
Trader Score: (0)
cabrio boy is an unknown quantity at this point
Send a message via MSN to cabrio boy
Default re
top stuff fella!
cabrio boy is offline   Reply With Quote
Old 13-06-2007, 11:25 PM   #43
ford crazy
ford crazy's Avatar
Trader Score: (0)
ford crazy is an unknown quantity at this point
COME IN ON WELL MATE
__________________
had my first ford at 17 havnt looked back
ford crazy is offline   Reply With Quote
Old 18-06-2007, 12:56 AM   #44
snozz2004
Trader Score: (0)
snozz2004 is an unknown quantity at this point
An update at last!
it took me a while to find some steel tubing for the oil return & breather pipes that needed to be fitted to the block, it wasn't really worth doing an update until i had that sorted.
Anyway heres the block stripped down, also made a blanking plate for the standard zetec breather.
Oil feed with standard & aftermarket oil pressure switch.
I drilled & tapped new exhaust stud holes, used an XR2i exhaust gasket as a template.
Camera broke! So theres a few photos missing of me drilling & fitting the oil return/breather pipes to the block & rebuilding the bottom end.
Pistons & crankshaft back in place.
sump, oil & water pumps back on the engine.
I bought a engine mount off Ebay thats been made for zetec engine conversions, the only problem i've had with it so far is the top part of it stops the cylinder head fitting the block properly,
quick chop with the angle grinder, & problem solved.
A peview of the engine, looking good
Next on the list, fit the bottom end & gearbox to the car, get the inlet manifold sorted & fixed to the head, fit 2 litre cams & start on the interior.
snozz2004 is offline   Reply With Quote
Old 18-06-2007, 10:52 AM   #45
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
Trader Score: (0)
AGAR-COSWORTH is on a distinguished road
Thats a great effort so far
Love mk3 cabs. Not many of them around these days.
__________________
Mk4 Golf GTI Anniversary - No. 1268
AGAR-COSWORTH is offline   Reply With Quote
Old 18-06-2007, 05:40 PM   #46
Jackass1983
Jackass1983's Avatar
Trader Score: (0)
Jackass1983 is an unknown quantity at this point
Hi,
do you use a decompresion plate? or?
What compresion ratio you want to drive?
Cheers Mark ( www.ST2000.de )
Jackass1983 is offline   Reply With Quote
Old 18-06-2007, 06:11 PM   #47
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Looking good mate
Brian
__________________
Brian is offline   Reply With Quote
Old 18-06-2007, 06:14 PM   #48
Trader Score: (14)
Twins is an unknown quantity at this point
__________________
My carbon clad s2
Twins is offline   Reply With Quote
Old 19-06-2007, 12:38 AM   #49
snozz2004
Trader Score: (0)
Quote:
Hi,
Hi, i'm using a decompresion plate, i think it will bring the comp down to 8:2:1
You can bring the comp down by having the piston crowns machined by 1-2mm, but i've heard that can weaken the pistons. If you have the spare cash, go for forge pistons, it's whats surpose to be used in this sort of conversion.
Old 10-10-2007, 02:24 PM   #50
snozz2004
Trader Score: (0)
Engine & gearbox have been fitted, the head isn't fitted yet, still got a bit of work to do on the inlet, it's just there for show.
I'm using a CVH oil filter which has plenty of room
Series 1 RS Turbo anti roll bar fitted
I've just started work on the inlet (taken from a rover 420 GSI)
Interior is going back in, had a few problems finding interior parts for a mk3 so i resprayed the panels in satin black.
I found a power hood at the scrap yard, took the lifters & pump & fitted to mine, cost me Ł20!
Fitted the hood & rear window.
Also gave the body a polish.
Old 10-10-2007, 05:23 PM   #51
749steve
Trader Score: (1)
749steve is an unknown quantity at this point
like this
some good work work done here
__________________
civic type r, gsxr 600 srad, giant xtc team
all cared for by
www.fstautomotive.co.uk
749steve is offline   Reply With Quote
Old 11-10-2007, 10:39 AM   #52
Dutch XR4i Driver
Dutch XR4i Driver's Avatar
Trader Score: (0)
Dutch XR4i Driver is an unknown quantity at this point
Send a message via MSN to Dutch XR4i Driver
Hi looks great
hope you wil have lots of fun whit it
here in holland the mk3 is not jet wanted like in England
Cheers Wiebe
Dutch XR4i Driver is offline   Reply With Quote
Old 31-01-2008, 04:27 PM   #53
snozz2004
Trader Score: (0)
Thanks for the comments guys
Small update:
I bought a engine mount off ebay near the begining of the build, i was told it was made to fit a zetec engine in a mark 3 & 4 Escort engine bay... But it didn't, so we made one are selfs,
1st. We moved & tig welded the lower bolt hole to the other side of the mount.
2nd. We made the fork section 1" longer (the bit that bolts to the rubber mount on the body)
Here's a few pic's of the mount after modds
Engine & box now fitted properly, all welding was done by a pro using a tig welder.
Old 31-01-2008, 05:55 PM   #54
stcabby
Trader Score: (0)
stcabby is an unknown quantity at this point
Top work fela, its nice to see people savin them from the crusher.
__________________
The harder it is the more rewarding it is!! Or so i keep telling maself?
stcabby is offline   Reply With Quote
Old 24-02-2009, 08:35 PM   #55
snozz2004
Trader Score: (0)
Xmas put a grinding halt to my project, the credit crunch didn't help either, but managed to get a few things done.
Put all the engine parts, manifolds & exhaust system together, just to see if eerything fits ok, so far so good.
I've finishing the lower half of the inlet manifold, had to cut some of the alloy away to match the adaptor plate, just need to smooth the ports.
I've decided to to fit a MK4 loom, it comes with EFI management loom installed which i can use FRST OFAC ecu with, i had an OFAB system already, but sold that & got an OFAC one.
I had a few problems with the loom, lots of cut wires, looks like someone removed an alarm system & didn't bother to replace the missing wire.
Took me a while but most of it is fixed
Still have one wire thats a bit of a mystery, brown with black strip that goes from the speedo, its broke & i can't find the other end? if anyone reading this page knows what it does, please let me know.
Old 03-03-2009, 07:44 PM   #56
snozz2004
Trader Score: (0)
Small update: MK4 dash board fitted with help from Smilers Site
Cylinder head is almost done, valve seated, chambers & ports cleaned up, just needs a skim
Hopefully i'll be building the engine by the weekend
Old 03-03-2009, 09:26 PM   #57
danny_boy699
chatter 4 life
Trader Score: (5)
danny_boy699 is an unknown quantity at this point
Send a message via MSN to danny_boy699
nice work mate, how come u fitted a mk4 dash. also how did u fitted the decomplate
__________________
check out the mk3 zetec turbo build
http://passionford.com/forum/restorations-rebuilds-and-projects/182173-mk3-escort-2-litre-zt-28-3-2010-geting-pissed-off-now-still-no-spark.html
Member of "The Daytime pf talk bollocks and random shite club #110
www.stocktonautocentre.com
danny_boy699 is offline   Reply With Quote
Old 03-03-2009, 10:28 PM   #58
Smiler
Smiler's Avatar
Trader Score: (0)
Smiler is an unknown quantity at this point
Impressive stuff! I had originaly planned a turbo conversion for my car too but funds just wouldn't stretch that far. In fact the whole project has laid dormant for goodness knows how long now.
Thanks for the link to my website by the way, good to see it gets used.
Keep at it, it's going to be quite something when it's done.
Smiler.
__________________
WWW.Auto-tat.co.uk
Also have:
2x BMW E34 (one being built as a tramp track day nail)
and a strange urge to buy something really big and impractical.
Smiler is offline   Reply With Quote
Old 03-03-2009, 11:17 PM   #59
snozz2004
Trader Score: (0)
Quote:
Cheers mate, fitted a mk4 dash because 1. i'm using a mk4 efi loom & i didn't want the hassle of rewiring all the switches & plugs 2. the mk3 dash was a bit fucked.
you fit the decomp plate in between 2 head gaskets (gasket, plate, gasket)
Smiler.
The decomp plate lowers the cost a bit, but i'm already planning on building a 2.0 with proper forge pistons, get it on the road first tho.
I've used your site a few time while building the car, very useful info on there, noticed we both got conned into buying a engine mount that doesn't fit properly.
Old 04-03-2009, 11:04 AM   #60
Smiler
Smiler's Avatar
Trader Score: (0)
Actualy, I modified my original mount from the old CVH. Then I managed to lose it during a house move and ended up buying another to modify from an already removed engine in a scrapyard. I modified it accordingly, went to fit it and discovered that it wasn't the correct Escort CVH mount. The wife subsequently found the original modified mount and that fitted a per the website.
As you can see from the website, I have somewhat overstretched myself now. I'm going to finish the Escort with the normaly aspirated 2.0ltr Zetec though I haven't decided on management yet. I started it so long ago that it was intended to use modified CVH EFi as that was all that was cheaply available back then. Of course the correct Zetec management is now cheap as chips and in plentiful supply but I already have the CVH EFi loom fitted. That was kind of why I was looking at going the turbo route with Fiesta RS Turbo management.
__________________
WWW.Auto-tat.co.uk
Also have:
Old 04-03-2009, 09:50 PM   #61
snozz2004
Trader Score: (0)
Is your management loom wired into the main loom or can you disconnect the management loom via a multi plug in the engine bay?
Old 04-03-2009, 10:07 PM   #62
danny_boy699
chatter 4 life
Trader Score: (5)
cheers mate if u need some colcks let me know i have a few sets of rev conuter clocks
__________________
http://passionford.com/forum/showthread.php?t=182173
Old 05-03-2009, 12:22 AM   #63
snozz2004
Trader Score: (0)
Yeah i'm looking for some clocks, PM me the price m8
Old 08-03-2009, 11:19 PM   #64
Smiler
Smiler's Avatar
Trader Score: (0)
Quote:
Sadly it's incorperated into the vehicle loom. Otherwise I'd have ditched it by now.
__________________
WWW.Auto-tat.co.uk
Also have:
Old 10-03-2009, 04:43 PM   #65
snozz2004
Trader Score: (0)
Same as mine & the main reason why i switched to OFAC management.
You could use 2i management, have it chipped to suit the engine
Old 27-03-2009, 06:55 PM   #66
snozz2004
Trader Score: (0)
I got the head skimmed, bought 2 head gaskets & put the engine together
Cleaned out & primed the cam followers & fitted the 2.0 litre cams, then realized i forgot to fit the crank position sensor holder in the block!
So engine back out, gearbox, clutch & flywheel had to removed to fit the holder.
sand blasted the cam cover, dip stick tube, lower section of the inlet manifold, throttle body & coil pack bracket, sprayed the cam cover, manifold & throttle body in silver & coil bracket & dip stick tube in black
Finished all mods to the lower section of the inlet manifold & bought allen bolts to fix it to the head.
Just need to get the top half of the inlet manifold modified now.
Old 28-03-2009, 12:32 AM   #67
danny_boy699
chatter 4 life
Trader Score: (5)
nice mate what throttle body u useingand what u modding on the inlet
__________________
Old 29-03-2009, 06:17 PM   #68
snozz2004
Trader Score: (0)
I'm using a fiesta rs turbo throttle body, had to match the ports of the lower section to the plate, also had to cut some of the casing because there wasn't enough room to get a bolt through.
See the 2 bolts to the left of the sensor in this pic, that part of the manifold is normally rounded, so i cut a straight edge & used allen bolts to solve the clearance issue
Old 30-03-2009, 11:26 PM   #69
Smiler
Smiler's Avatar
Trader Score: (0)
I'm getting jealouse!
__________________
WWW.Auto-tat.co.uk
Also have:
Old 26-09-2009, 11:30 AM   #70
POHelbert
Trader Score: (0)
POHelbert is on a distinguished road
Send a message via ICQ to POHelbert
Default Erectile Dysfunction Physical Pain Pinching
fuck off spammer
POHelbert is offline   Reply With Quote
Old 20-10-2009, 06:47 PM   #71
snozz2004
Trader Score: (0)
It's been a while, mainly dew to my dad restoring a triumph spitfire, picture of the finished product below.
So while that was going on i spent my time cleaning a few things up, sandblasted the intercooler, gearbox mounts & top half of the inlet.
Wire brush attachment for the angle grinder help alot with the driveshafts
Managed to track down a Series 1 body kit not to far from my location.
S2 RST brake disc's & calipers, another ebay bargin, these will get a good clean up before fitting.
MK4 dash painted satin black & fitted, many thanks to danny_boy699 for the speedo
Found MK4 RST black carpet on ebay, looks better than the old grey & faded carpet
Mocked up the alternator, everything is good here, just got to finish the bottom radiator hose.
Figuring out where & how to position the throttle body.
Driveshafts painted & fitted, should have took a picture of them before fitting, but got carried away.
Old 21-10-2009, 08:56 PM   #72
Smiler
Smiler's Avatar
Trader Score: (0)
Looking good, those mk4 dashboards look so much better in black don't they. What paint did you use? Used some specialist paint particularly made for painting items such as dash boards and it's rubbish, it's started lifting and peeling and I'm not happy about it. I would redo the whole thing but in some places it's stuck really well so I'd end up with lumps and patches.
Nice to see the alternator has gone on no problem, I have finally restarted work on mine and the alternator is almost next on the list.
Spifire looks nice by the way, I quite like old Triumphs. I'd quite like to lift the 2.5ltr 24 valve straight six out of my track day Beemer and drop it into an old Triumph 2000 saloon car.
__________________
WWW.Auto-tat.co.uk
Also have:
Old 21-10-2009, 10:27 PM   #73
snozz2004
Trader Score: (0)
Went to a car paint shop & asked what i should use, the gave me some plastic primer & standard satin black cellulose paint, i also wiped it down with thinners & used some pre paint liquid on it before priming.
I used a KA alternator, but had to modify it slightly with an angle grinder
Sounds like a plan, you should do it, plenty of room under the bonnet.
If you want to see more pictures of the triumph i have them hosted on photobucket click
Old 21-10-2009, 10:48 PM   #74
steve st220
"SNIFF MY DIFF"
steve st220's Avatar
Trader Score: (0)
steve st220 is an unknown quantity at this point
Send a message via MSN to steve st220
your doing well there mate, i'm in the middle of restoring a mk3 se cabby
__________________
Blue Oval Enthusiasts Club<<<< click
steve st220 is offline   Reply With Quote
Old 22-10-2009, 01:34 AM   #75
snozz2004
Trader Score: (0)
Quote:
Cool, you going to post pictures of your rebuild m8?
Old 22-10-2009, 04:02 PM   #76
steve st220
"SNIFF MY DIFF"
Trader Score: (0)
heres a few pics of mine for you
just waiting on paint now
__________________
Old 03-11-2009, 06:53 PM   #77
gagzyboy
mk3's are the nutz
Trader Score: (0)
gagzyboy is on a distinguished road
loving the update mate, nice work very inspiring ;0)
gagzyboy is offline   Reply With Quote
Old 03-11-2009, 10:43 PM   #78
dingla rs
dingla rs's Avatar
Trader Score: (1)
dingla rs is on a distinguished road
look like my old turbo clocks if they ofa danny
__________________
loysport
http://www.bafabrications.co.uk/
PM MONSTER FOR CUSTOM VIN TAGS
carpartsexpress mail order ford parts 01914272186
dingla rs is offline   Reply With Quote
Old 21-11-2009, 12:47 AM   #79
Smiler
Smiler's Avatar
Trader Score: (0)
Just re-discovered this thread and taken a look at those pics of the Spitfire. Looks like a very good proper job, nice work.
__________________
WWW.Auto-tat.co.uk
Also have:
Old 21-11-2009, 10:44 AM   #80
danny_boy699
chatter 4 life
Trader Score: (5)
Quote:
they could be mate, i had 2 sets that i sold at the same time, i know yours where lockwood 1's
nice work mate keep it up
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
