Group 2 Zakspeed Mk2 Escort Project
I've been doing this for about a year now, but have finally got around to putting some stuff up on here.. the idea is to turn it into a fast road/trackday car by the time it's done...
Here's some photos of when it arrived at my place:
It's come on quite a lot since then, and I'll put some more pics up later or tomorrow.
ok, so when i first got it i stuck it up on some stands to see what the deal really was.. pleased to say I didn't find any real rot.. just a couple of very small holes in the drivers side foot well, and the front legs are the capri type - which is what I'll need to send them off to Gaz as exchange for the nice new coilovers that will be going on in a few weeks... the doors are a bit manky but they'll be replaced. (I've already got one in my shed waiting to go on.)
Not sure if these are in order.. but it gets a lot more interesting after this bit....
horrible rear panel.. may be replaced or might repair.. not sure yet..
Glass and interior out and front treated and primed...
Most of the sound proofing removed from the interior:
Interior finished and etch primed:
Loom out and labelled
Underseal all removed and underside primed
Wings removed:
Hole in A Pillar:
Wings removed:
Hole in A Pillar:
The car is now at Retromotorsport in Harlow for some fabrication work to be done... this is where it is currently so I'll have to post them up as they go...
Holes in the floor have been repaired....
And Gary's also started to move the bulkhead back 2 inches to allow me to mount the engine further back and lower...
Bulkhead now finished:
(there's more taken out on the left hand side deliberately.. all will be revealed later!)
Large Gearbox tunnel fabricated and installed.. apparently I should be able to change the clutch in 20 minutes on my own with this little puppy
Large Diff tunnel also fabricated installed:
Raised Prop tunnel added to complete it
Just needs a hole for the handbrake and gearlever which will be done when I get my engine and box up there to ensure it's spot on!
This is where it's at as of today. I'll post some more pics up as and when I receive them
My mistake.. it was the tubs!
Before...
Marking out the metal the be cut...
now that's a hole!!!
Turret's in...
Tubs...
Firewall mounts made and fitted...
The finished product....
To say I'm chuffed is a huuuuge understatement!!
Big to Gary @ Retromotorsport for all his hard work!!
Before...
Turret's in...
Tubs...
Gary also temporarily fixed on one of my Group2 Zakspeed arches and put a wheel he had there in position to give an idea of what it will look like when my proper ones show up (hopefully the next day or so!)
How cool is that?!?!?
