Dax Cosworth
Old 31-12-2016, 08:17 AM
Max Dax
Max Dax's Avatar
Default Dax Cosworth
Hi I am Max,
my first post here, I am not a "talker" or writer in this case. I will fill the thread mainly with pictures as I am going through the build/change process. Lots of changes are already done but I'm not finished yet.
Goal is: 360HP and 600kg wet.
picture as I bought the car 1 year ago.
thank you all for sharing the information which is already on this forum!!
Old 31-12-2016, 08:25 AM
Max Dax
Max Dax's Avatar
New turbo. Twinscroll. Ballbearing.
Manifold.
Old 31-12-2016, 08:38 AM
Max Dax
Max Dax's Avatar
Like to work with carbon. (Infusion)
Old 31-12-2016, 08:48 AM
Caddyshack
Caddyshack's Avatar
Welcome to the forum, love the Dax, there is another on here and also running efr. Is that manifold a true twin scroll? Is it a modded 2wd one?
Do you make the carbon yourself? How?
My sister lives in Auckland
Old 31-12-2016, 09:53 AM
mattman1234
mattman1234's Avatar
like the sound of this one
Old 31-12-2016, 09:56 AM
Max Dax
Max Dax's Avatar
Thanks,
yeh its real split manifold to have the most out of the twinscroll.
Carbon work is done with vacuum infusion. Check youtube. Most of the carbon work is making the plug and the mold..
Max
Old 31-12-2016, 10:00 AM
mattman1234
more pics,,more pics,
would love this turbo on mine
Old 31-12-2016, 11:26 AM
Max Dax
Max Dax's Avatar
Quick test to see if the airflow in the cooler can be inproved.... just +1% in flow. Expected a bit more. Will not be executed i think. Without sharpening
Sharpend with wood to do the test.
As is.
Displayed is airspeed. With calculation to airflow m3/h it is 1% gain.
Old 31-12-2016, 11:30 AM
visa_broke
visa_broke's Avatar
interesting idea for the intercooler, i've not seen that done before
Old 31-12-2016, 12:27 PM
jontysafe
jontysafe's Avatar
Hello there and welcome
im fitting the slightly larger sibling of your turbo efr7163 and so is Porkie on here, both on Westfields.
what psi are you going to be running?
Old 31-12-2016, 05:58 PM
Max Dax
Max Dax's Avatar
Did some calculations a while ago for this engine. Hope they make sense…
Old 31-12-2016, 06:59 PM
Caddyshack
Caddyshack's Avatar
Oh yeah, perfect sense....looks like it is running lean on cylinder 6 though
Cos500 (01-01-2017)
Old 02-01-2017, 01:20 PM
Max Dax
Max Dax's Avatar
Plug for side panels. Can be used for L + R.
Mold. Will be cured in the oven before its used for infusion.
Old 02-01-2017, 03:00 PM
PaulinhoT
PaulinhoT's Avatar
This looks great interesting read, thank you.
Old 02-01-2017, 04:32 PM
Mark Shead
Mark Shead's Avatar
Manifold.
Why are you using internal gated housing on to a external gated manifold.
Mark
Old 02-01-2017, 05:19 PM
Max Dax
Max Dax's Avatar
Mark
Hi Mark.
I bought the turbo first, based on the spec's.
Manifold didnt fit in the Dax so i had to cut a bit.... hope the internal is good enough. Same with the blow off... first want to try with the internal. Mayby later on i do both external.
Its just for 360hp so i trust that turbo alone can do the job. (Capeable for 400 as advertised)
Please share your thoughts..
Old 03-01-2017, 06:55 PM
mattman1234
any pics of the whole engine bay,,want to see how big/fitment of turbo
Old 08-01-2017, 09:58 AM
Max Dax
Max Dax's Avatar
Infusion ready. Wait till ist cured.
Old 08-01-2017, 11:30 AM
Caddyshack
Caddyshack's Avatar
I have got a spare one of those intercoolers if you want it free
Old 09-01-2017, 04:10 PM
Max Dax
Max Dax's Avatar
Old 09-01-2017, 04:12 PM
jontysafe
jontysafe's Avatar
You may find you need more intercooling.
Old 09-01-2017, 04:35 PM
Max Dax
Max Dax's Avatar
thanks,much appreciated. I am ok for now.
yeh jontysave, maybe you are right what is the restriction the cooling or flow? both I guess....
lets try and see with this one. (have my own dyno so I can test and find what the restriction is)
for now I am going for the shortest/smoothest way to the intake.
thanks
Old 09-01-2017, 04:55 PM
jontysafe
jontysafe's Avatar
thanks
will be the cooling. What works in a sierra/escort wont necessarily work in a 7 clone. This is my Garrett cored intercooler for 29psi on the efr7163 in a Westfield nose cone.
Old 09-01-2017, 05:59 PM
Caddyshack
Caddyshack's Avatar
I have got an airtec 100mm thick one, it is about 3 times the size if this standard one and is as big as an rs500 one, just thicker and more efficient, I still get 20-30 degrees c regularly and have seen 50c peak. I think anything over 300bhp you will need a much bigger core, not for flow, you need surface area.
Old 12-01-2017, 05:54 PM
Max Dax
Max Dax's Avatar
Thanks.
Based in your comments I start thinking how to fit a bigger cooler without adding to much pipping. Still want the shortest line to the intake.
See flowresults with new intercooler intake.
thats 12% improvement..... did not expect that.
Old 12-01-2017, 06:20 PM
jontysafe
jontysafe's Avatar
Thanks.
how are you measuring flow? I think people always get a bit tied up wanting the shortest intake piping with a turbo. At 29psi on your set up and 2" intake piping gas speeds will be up around Mach 0.4. 1ft of pipe or 6ft of 2" pipe will not make any difference.
Old 17-01-2017, 08:58 PM
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
Hi Maxdax,
i too have a cosworth rush though mines the 4wd variant. what vintage is yours?
great to see your intercooler testing, though as someone said in an earlier post on this thread, the cosworth 4wd intercooler may not be big enough. i think it has good charge air flow (low restriction) because its very deep with wide tubes but not a lot of frontal area. also in the rush, its positioning means that it gets heat soak from the rad below it when you are at the traffic lights. sevens also typically dont evacuate the hot air in the bonnet area very well.
about 20 years ago Dax supplied a thing they called a 'splitter' which divided the air coming through the nose cone between the engine rad and the intercooler. they also provided a curved upswept fibreglass thing which was meant to deflect the air exiting the intercooler upwards. it didnt work because the air pressure over the nose cone was greater than the pressure exiting the intercooler.
its difficult to measure inlet air temps in a yb (at least it is when the yb is in a 7) because of heat soak. over the last year ive done some data logging and measurirng of IAT's however and i believe that an air water intercooler is the most effective solution for a road going 7 though clearly its more complex.
as soon as i saw the picture you posted of your manifold i thought 'that wont fit in a rush!' due to the external waste gate which i see you've cut off. did you get the manifold custom made?
i think the turbo you have will be better than the larger 7163 for road use. i put a 7163 on mine and it makes loads of power from 37 psi @ 5000 onwards but substantially less lower down than the dyno plots show for the other efr turbos. for this reason ive now bought a 7064!
borg warner have a marvelous program called matchbot which you can download. you tell it info like engine size, boost pressure required at what rpm, intercooler details etc and it will calculate what efr turbine wheel and compmressor wheel you require to get your objectives.
Old 18-01-2017, 09:01 AM
20/20 vision
Hi again Maxdax,
looking at your intercooler again i may have incorrectly assumed it was a cosworth 4x4 one when in fact it was a 2wd one? although the 2wd one is shorter, even then it looks like the unit will be too wide for a dax chassis with those end tanks on. does it fit ok?
Old 18-01-2017, 09:12 AM
AustenW
AustenW's Avatar
Nice project, subscribed
Old 18-01-2017, 08:22 PM
Bart
Bart's Avatar
Originally Posted by 20/20 vision
Hi Maxdax,
Is the 7163 for sale?
Old 19-01-2017, 12:10 AM
20/20 vision
will be soon i hope together with a very compact twin scroll manifold - once i get the 7064 fitted.
getting the 7064 in has required fabrication of a new manifold which due to the lack of space is probably the most complex thing I've ever done on a car!
Old 19-01-2017, 01:10 PM
jontysafe
jontysafe's Avatar
What makes you think the 7064 will spoil better than the smaller framed 7163?
Old 19-01-2017, 08:40 PM
Bart
Bart's Avatar
Let me know when you sell it, i am interested.
Old 20-01-2017, 12:08 AM
20/20 vision
Hi Jonty, Maxdax - sorry for the thread highjack!
well, firstly because Mark Shead has said so on several posts, secondly his various dyno plots show that is does spool better compared to my results, thirdly because of this video
https://www.youtube.com/watch?v=q3PfyeLALPM
and forthly because the borg warner matchbot program says it will.
i found the matchbot program is really enlightening. you can tell it what boost you would like to see at what rpm for a given engine size and you can then dump those figures onto any of thier current compressor maps which, of course, also gives you the speed the turbo needs to spin at for that boost at whatever air flow is required. it then will work out how much power the turbo shaft needs to develop and which turbine is capable of making that power at that turbo speed. you then 'tune' the lower graph to ensure they have a turbo with matched turbine for your situation. the 7064 seem to look better than a 7163 for a 2 litre engine in terms of early spooling.
im not saying that the 7163 is a bad turbo for a yb - far from it. its easily the best turbo i have used but i have no experience of anything newer than a TT38. it's certainly makes my car quick and almost scary from about 5k onwards and would be probably quite well suited to a typical 7 2wd in so far as the boost doesn't come in with a kick like a t34 does which can easily light up the back wheels. i think the 7163 might be be a good track turbo for a high revving 7 but less so for a road going 7 with a 3.6 diff. 5th would never get into the full spool unless you're doing 90mph as you're typically trying to keep it over 4500 to make it work. 7's aren't usually used as high speed motorway cars so why have gear ratios / turbo which is suited to that environment? i haven't looked at the 6258 or 6758 in matchbot but i think they would look better for a road 7 than a 7163 is.
I've got a 4.4 diff, an 800kg car with 8:1 comp, home ported head, bd15/16 cams. i dont know how much impact the cams have but in my limited understanding of the situation you dont need std short duration cams with twin scroll and you benefit from the higher lift & longer duration. happy to be corrected on this however if someone thinks that my cams are impacting on my spoolup. i have played around with the cam timing +-5 degs on each one from a start of 110 / 110 with little impact.
It's also possible that a tuner would get better spooling results than i did. it has been on a rolling road but the guy didnt really know much about it and said that there was too much noise for him to use his det cans?????? so he left the timing safe at 5 degrees AFTER tdc when it was on boost - waste of time imho. maybe someone who knew what they're doing could improve spool by adjusting cams / ignition.
I'd post up the data log if i could understand how to do it but it shows the following:
in 4th and flooring it from 1765rpm we took 5.5 seconds to get to 4904rpm with boost as follows:
3500 - 14.3psi
3709 - 17
3813 - 19
4000 - 22
4300 - 28
4700 - 32
i also tried holding in the brakes to load it up but that didnt improve the boost figures
by contrast, the engine in the vid seems to be making 480lb ft at 3500 at 2.6 bar @38 psi
Old 20-01-2017, 10:31 AM
jontysafe
jontysafe's Avatar
I would would be looking at your tune and exhaust port sizes. You're going to find little difference by changing to the 7064. There in reality will be circa 300rpm +/- difference in spool on a yb between the two.
3500 - 14.3psi
3709 - 17
3813 - 19
4000 - 22
4300 - 28
4700 - 32
Old 20-01-2017, 11:25 AM
20/20 vision
but what reasoning do you have to support that view?
Old 20-01-2017, 11:31 AM
jontysafe
jontysafe's Avatar
Mostly speaking to the tech guys at Full Race when I was choosing my turbo.
plus you only have to look at the differing turbine sizing between the two.
Old 20-01-2017, 12:38 PM
20/20 vision
oh, well.. apart from the 4 reasons i gave before there is also this clip from an email conversation i had with someone who should know....
Paul,
The best way to compare the two turbos is Matchbot. I started the link below for you.
http://www.turbos.borgwarner.com/go/O5KDPT
Please go there and adjust the input parameters to match your set up. Once you have done that you can use the drop down menu to compare the two different compressor stages.
The 7064 will allow more pressure ratio early in the RPM range based on the positioning of the surge line.
You will see this in Matchbot.
Other things that are super critical to seeing earlier boost response is to have a twin scroll turbine housing and a divided exhaust manifold timed correctly to take advantage of pulse energy.
This combination will improve initial boost and transient boost response by as much a 15%.
Please tell me what performance distributer you are buying from?
Thanks,
Brian Rhinehart
BorgWarner
IAM Tech Service
anyway, its nearly fitted so we shall see
Old 20-01-2017, 01:00 PM
Mark Shead
Mark Shead's Avatar
What you have said is completely wrong and not from a experienced point of view. The 7064 monsters the 7163 in every area past 3000rpm there is no comparison between the two from there.
The only area the 7163 is very slightly better is at 2000rpm to 2.5k due to the exhaust flow restrictions that kill that turbo as soon as you want big boost. Overlay the comp map on both and it's as plain as day to see.
Mark
Old 20-01-2017, 06:33 PM
jontysafe
jontysafe's Avatar
Mark
is he not talking about initial spool? Also on a YB powered 7 you can't really cool the charge enough to go over 28-29 psi so that monster mid range torque that you could have in a saph with a decent intercooler isn't an option.
