Mondeo mk3 2.0 duratec into escort mk6
Old 24-08-2016, 07:59 PM
Dan91
Dan91's Avatar
Default Mondeo mk3 2.0 duratec into escort mk6
Looking to put the 2.0 duratec out of my mondeo into mk6 escort as a bit of a project I'm going to use the mondeo gearbox what shafts and hubs do I need, also how will it work ecu wise I no it would be easier for aftermarket management but would I be able to use the mondeo ecu to run the engine any help or in site would be much appreciated
Old 25-08-2016, 06:51 PM
big_wasa
big_wasa's Avatar
I can't help with the fitting but
I do know a thing or two about the oem engine management side of things.
I havnt done the Mondeo duratec yet but I have done most of the other four pots.
I am working on the focus Rs ecu at the moment.
When done I share all the pin out info.
http://www.locostbuilders.co.uk/view...php?tid=190440
If you have the full Mondeo loom from a 2.0 manual I may be up for lending a hand.
I did buy one to pull to bits but ended up using it as my daily until I've got somthing better sorted.
Old 26-08-2016, 06:47 PM
Dan91
Dan91's Avatar
Tbh the fitting I'll be able to work out I haven't got a escort to put it in yet but the mondeo sat on my drive atm it's just something I was looking into as a project for fun like I've worked on other cars but not done anything project wise with a Ford, but i think wiring would be the only thing that would trouble me. Just trying to get as much information as possible before I go ahead and start something I can't finish lol
Old 19-10-2016, 06:35 PM
disco-stu
disco-stu's Avatar
I did look into using duratec into my mk6 escort but it was the problem of the inlet being on front which started my change of plan back to a zetec. Looking at the exhaust manifold for the duratec I was pretty sure it wouldn't clear the subframe and then getting a gearbox to match as well as the zetec has the starter on the back as upposed the duratec on the front matched with the cable clutch aswell
Old 19-10-2016, 06:45 PM
Dan91
Dan91's Avatar
I did wonder about the exhaust manifold but I think some clever manufacturing would solve that as for the gearbox I read somewhere u can use the mondeos gearbox mtx75 I think it's called and u have to change the hubs to suit the driveshafts but that's as far as I got I haven't found one that's been done yet and think it would be a good challenge just still gathering bits and pieces of information from where I can before I proceed with buying a shell to put the lump in
Old 19-10-2016, 07:33 PM
disco-stu
disco-stu's Avatar
And the subframe aswell for the mtx75 box
Old 14-02-2019, 07:38 AM
Matt Leak
Matt Leak's Avatar
How did you get on with this I'm looking to drop a Mondeo st 2.2 in a mk6 cabrio if seen a st with gearbox ecu loom the lot at minimal money but also seen mk2 Mondeo subframe with hubs arms etc is it doable
Old 14-02-2019, 09:18 AM
st220kyle
st220kyle's Avatar
The 2.2 is a diesel engine, are you sure that's what you want to put in an escort?
Old 14-02-2019, 09:33 AM
Matt Leak
Matt Leak's Avatar
any suggestions I'm open ears its my first project know a few bits here n there n can weld and fabricate so an open book really.....
Old 14-02-2019, 11:08 AM
big_wasa
big_wasa's Avatar
If you want something really different but still ford then the st220 hasn't been done yet into an escort ( that i know off ).
I've done the pin outs but I am still busy with the rwd zetec turbo. Simple remap for 250bhp, It's going to be rwd as well.
There are a couple of 2.5 v6's into fiestas so it's got to be doable.
I love a zetec but it's done to death but an st170 on throttle bodies would be best bang for buck.
If you have deep pockets then its the eco boost.
Old 14-02-2019, 04:49 PM
Matt Leak
Matt Leak's Avatar
Wats the pin offs? If seen a Mondeo st 2.2 tech although a dirt diesel engines ain't bad would you suggest getting a mk2 Mondeo subframe
Old 15-02-2019, 10:45 AM
big_wasa
big_wasa's Avatar
Pin outs are the information on what every pin coming into and out off the ecu is and does allowing you to take it from the donor and run it in a project. Anything from a boat to a plank of wood.
So you can run an engine on the factory map at very little cost. St170 or zetec for a tenner plus your time. Or say omex or megasquirt plus loom plus mapping. Circa £1500.
The trade of is power against cost.
Turbo zetec on Focus Rs engine management.
Rwd St170
And I've done several others.
Old 15-02-2019, 11:37 AM
Matt Leak
Matt Leak's Avatar
That's sweet I'm looking at doing the st220 petrol hoping to use the complete loom whole rewire if it's easier I'd like some info of using a complete mk2 subframe
Old 15-02-2019, 11:57 AM
st220kyle
st220kyle's Avatar
I don't think a mk2 Mondeo sub frame is going to be much use for what your doing, why do you want to use it?
Old 15-02-2019, 12:20 PM
Matt Leak
Matt Leak's Avatar
Well thought I could mod it to house the st engine with running gear I would need to measure current escort width hub to hub along with Mondeo
Old 15-02-2019, 04:53 PM
big_wasa
big_wasa's Avatar
The st engine doesn’t mount to the subframe. It hangs of the inner wing/ chassis legs either end with a gearbox brace to stop it rocking.
Old 15-02-2019, 09:04 PM
Matt Leak
Matt Leak's Avatar
I was looking at the subframe more for the brakes driveshifts suspension ect
Old 26-02-2019, 12:26 PM
IanC
IanC's Avatar
Budget St170 engine on oem ecu first full run. - YouTube
what are you upto with the focus rs ecu pal?
Old 26-02-2019, 08:25 PM
big_wasa
big_wasa's Avatar
Turn it around 90deg and plonking it in a kitcar.
Then I need to get rid of all the left overs
Old 27-02-2019, 04:39 AM
daren5675
27-03-2016 10:57 AM
disco-stu
16-03-2016 07:35 AM
kevin micallef
06-03-2016 05:36 PM
Rs(555)
28-02-2016 08:31 PM
18-11-2003 10:59 PM
Quick Reply: Mondeo mk3 2.0 duratec into escort mk6
