My new sapp..making a start on a make over
#121
Just fitted a lot of bits and bobs.
1. Remove diff,replace seals, refit with new bolt kit,new diff mount and some nice Fuchs oil.
2. Change engine oil(Fucks Pro S 10w50), oil filter, sump plug and washer.
3. Change gearbox oil with some Motul ATF.
4. Replace and bleed through brake fluid with Brembo dot 5.1 fluid and fit new Goodridge front brake hoses.
5. Fit new spark plugs 071c and new plug leads and move coil.
6. Adjust handbrake slightly.
7. Fit new clutch cable, nice job, ratchet and pawl snapped so had to order a new ratchet from Ford.
8. Fit new cap and rotor arm plus a new sensor kit.
9. Fit new fan loom, fuel pump loom and alternator to battery cable,great products, thanks to James Autodynamix for providing the parts.
10. Fit Kevlar diaphram for the dump valve.
That's about it for now.
Thanks. Lee.
Thanks. Lee.
#122
Ordered some more goodies that came a few days back from Ford.
Had some new T peice stainless front bumper brackets arrive, ready painted up in satin black.
Bought another set of Pioneer speakers for the rears this time,match my front set I purchased a few months ago.
That's it for now.
CheeRS.Lee.
That's it for now.
CheeRS.Lee.
Staffi (19-08-2016)
#129
Collected a few parts I was after lately.
New alternator heatsheild with longer bolts and washers.
Another pair of new headlamp wiper blades.
The headlamp wiper arm I was after as I broke mine, 2 airbox clips and the clip that secures the top fuel pipe to the fuel pressure reg.....thanks Paul, your a star.
Thanks. Lee.
Thanks. Lee.
#133
A few minor updates.
Sold the Autronics as I decided I didn't want to go down that route.
I managed to source a very tidy airbox at reasonable money. Purchased a new K&N panel filter.
New pack of tow cover ties and another fuel pressure regualtor, that's 3 I have now..lol.
Got new Ford bonnet stay spacer and clip plus some fog cover screws.
More to follow.
Thanks. Lee.
More to follow.
Thanks. Lee.
#134
As it was Rally Day yesterday, last week I decided to take the wheels off again clean and seal them up then clean up the arch guards, suspension and brakes as I haven't done this for 3 months, I thought it was time to give it another going over, not to bad this time around as when I did this originally it was grimy,nice again now for 5 mins.
Just 2 pics of front wheels and one front arch,just clean and tidy so I am happy....for now.
Thanks. Lee.
Thanks. Lee.
#136
Looking into getting some new tyres soon as the previous owner fitted a set of wong pong things,not the sort of thing to fit to a Cosworth is it.I'm looking at Bridgestones or Toyo possibly, a very limited choices are available for the 205/50/15 range.
The underbonnet resto is on hold temporarily until the winter months as my painter has lots going on at the moment.
Thanks. Lee.
Thanks. Lee.
#138
Had a new fuel rail to reg hose, 2 reg bolts as they were missing altogether and new clips for the fuel hose(thanks Paul Costina your a great help)
All fitted up.
Got some 4wd rear calipers,sending them off for a refurb to Bigred.
Thanks. Lee.
All fitted up.
Thanks. Lee.
#139
I thought my turbo was a t34 with a .48 ex housing. I have since checked the paperwork and it is a Turbo Technics T35 stage 3 hybrid, has 360 bearing and cut back blades with .55 ex housing, so that is a bonus.
Got a PF09 TPS coming back in the next few days.
Underbonnet resto will be starting in a round a months time, so a bit sooner than I thought and a bit of paintwork at the same time, this will be the winter project.
Thanks. Lee.
Thanks. Lee.
#141
Thanks. Lee.
#144
New ISCV and rear diff hanger poly bushes. New throttle body support bracket and new rear caliper bolts.
New genuine Ford ignition amps and 2 amp brackets, plug for PF09 TPS and new FPR bracket.
New plug lead bracket, manifold to turbo bolts/nuts and cambelt tensioner nut and bolt.
Thanks. Lee.
Thanks. Lee.
#146
Very nice, and a lovely looking car
#149
Passionford Addict
Cars going to be a stunner when your finished with it fair play to you. A wee bit OCD but I'm exactly the same lol.
Out of curiosity how much did big red charge to do the calipers as I've a couple of sets sitting I wouldn't mind being refurbished
#152
Rear 4wd calipers Ł130 plus postage each way, so around Ł150 in total.You can have the normal zinc finish for less money, depends what finish you want.Will be getting the fronts done after xmas.
Thanks. Lee.
xr2john (13-11-2016)
#153
[QUOTE=155lee;6705562]Did you change your diff mount bushes?
If so was there any difference in noise?
Also,would you sell 2 foglight cover screws??[/QUOTE
Alright Lee. No haven't fitted the diff mount bushes, probably won't until next year now.I will be using the fog screws, not sure if 4 or 8 are required I will have to check.If 4 then I will sell you what you require.
CheeRS.Lee.
CheeRS.Lee.
