Fiesta mk4 project
Old 06-05-2016, 02:39 AM
cypressbill
cypressbill's Avatar
Default Fiesta mk4 project
HI ALL. HERE IS MY NEW THREAD I THINK YOU'RE GONNA LIKE.
i brought my '97 mk4 fiesta 1.3 LX for £270 in october and i really want to turn it into something special. its the 1st car ive had in 10 years so my insurance is a bit pricey
ive been looking around for ideas over the winter and have come up with a plan. i want a fast road car which is easily adaptable into a rally car.
funny thing is i am not a mechanic, i used to be a chef so i'm very good with my hands and have an eye for the details, my motto really is if it aint perfect then i need to try harder.
i strongly believe that with the right research, tools, advice and willingness to succeed i can achieve anything.
i've changed brake pads, oil and spark plugs on my mk2 XR2 years ago installed car audio systems but thats about it. what can go wrong (he said nievely) lols
my plan is as follows:
bigger wheels 15"
LP tires 195/45/R15
lowered 40-50mm all round on fully adjustable springs and dampers`
polybushed all round
rear brake disc conversion
uprated front calipers, discs and pads perhaps from a mondeo or focus
sports exhaust system
mk5 zetec S front/rear bumpers,
side skirts and a rear diffuser which i'm gonna make myself
rear spoiler and front aero kit
1.7 Zetec puma engine 1st then 2.0 Zetec later on which will be super/turbocharged
ive got an idea for some different head/side lights `like on the american dodge charger, individual round lights set back with a big grill in the middle what do you think of my plan overall?
this is the car the day before purchase
Attached Thumbnails Fiesta mk4 project-12346698_10207075786485992_536513004_n.jpg
Old 06-05-2016, 03:22 AM
cypressbill
Default 1st hurdle
first up was wheels. i paid £80 for these with tires and more importantly no curb marks
rubbed them down
primed
painted matte black
i used spray cans. never spray painted anything in my life but well happy with the result.
i thought i'd go the extra mile and got hold of some vinyl wrap carbon look. look ok dont they?
Old 06-05-2016, 08:15 PM
gjh
gjh's Avatar
Very nice! I own a mk4 myself, very under rated, keep us updated!
Old 07-05-2016, 09:52 AM
cypressbill
picked up this baby for £30 a bit dirty with a few scuffs but no damage . so after a few days hand sanding and a quick rattle can prime and respray it looks brand new
Old 07-05-2016, 09:56 AM
cypressbill
Old 07-05-2016, 10:01 AM
cypressbill
having the new wheels on is a transformation
Old 07-05-2016, 10:06 AM
cypressbill
back bumper £37 from ebay same as front no damage but needed respraying
Old 07-05-2016, 10:07 AM
These mk4 fiestas are a good car
Sadly most of them have rotted away now.
Old 07-05-2016, 10:11 AM
cypressbill
test fitted the bumper. had to cut off 2 small bits of plastic to get it to fit right other than that just bolts straight on. also fitted the exhaust which is called a hornet £32 from ebay
Old 07-05-2016, 10:12 AM
Mk4 Rick
Mk4 Rick's Avatar
I had a 2 litre zetec mk4 fiesta .I had a donor mondeo to get the bits from though.It was an easy swap
Old 07-05-2016, 10:17 AM
cypressbill
yeah i know what you mean. i ripped out the rear arch liner and found this
ive been out with the angle grinder yesterday most of its gone now. gonna strip the bottom from the fuel tank to the rear back to bare metal and zinc primer ,stonechip then waxoil. weve got some nice weather atm so best time to do it
Prince_Thain
Prince_Thain's Avatar
Interesting seeing a 5 door one of these done, which will be very different.
Sounds like it will end up being very expensive by the time you're done. Perhaps work out how much you would have spent by the end of it and think about what other car with decent power etc you could get for that price.
I have a project and realised I could have got an ST by the time I finished!
Yours would be far more unique though, well done on what you've done so far.
Old 07-05-2016, 10:42 AM
cypressbill
i see what you mean. it would have to be a new ST though as i dont like the mk6.
Old 07-05-2016, 10:45 AM
cypressbill
i do like the diffuser
Old 07-05-2016, 06:41 PM
cypressbill
this is a common problem with the mk4
its the drivers door sill
by the time i got rid of the rust it lookled like this
now i would like your thoughts on the next one please is it a or
i used expanding foam for the cavity and ill use this to fill
what would you have used
Old 07-05-2016, 06:57 PM
Scott_Rst
Scott_Rst's Avatar
Nice wee project mate, not being rude,,but expanding foam and filler ontop is a total bodge job,, always remove rust then replace with fresh metal, just my 2pence worth!
Old 07-05-2016, 07:20 PM
cypressbill
thats what im after constructive criticism. buying a welder is on my shopping list. will this do for the time being ?
Old 07-05-2016, 07:35 PM
cypressbill
good old fiesta arches
Old 07-05-2016, 07:50 PM
cypressbill
no expanding foam was used during this process
got another layer of filler to go on
Old 07-05-2016, 08:17 PM
mk1turboestate
mk1turboestate's Avatar
Please don't leave the expanding foam in, get it welded properly, other than that good effort
Old 07-05-2016, 09:23 PM
cypressbill
hycote zinc primer goes on thick
Old 08-05-2016, 07:26 AM
clairendave
Dave not Claire.
clairendave's Avatar
Expanding foam will absorb any moisture/water it can get its pores on. That little hole will be a huge issue in time to come. The foam will also make it messy to weld properly now. Keep it up tho, just loose the foam
Dave
Old 09-05-2016, 09:10 AM
cypressbill
gonna finish the rear arch then test fit the front bumper . as i understand it some slight modification is needed with a file. we shall see
Old 09-05-2016, 09:48 AM
cypressbill
i found this earlier . how bizzare. rear end ford focus
front-end mk 5 zs fiesta the ford ikon as its called
Old 09-05-2016, 10:05 AM
cypressbill
the rear arch is looking much better. anyone with an idea for a replacement arch liner, something that water doesnt soak into like the std one ( stupid idea ford)
Old 09-05-2016, 10:07 AM
cypressbill
Old 09-05-2016, 11:27 AM
cypressbill
i have listened to your advice about the foam and you'll be pleased to know its going as soon as i get a welder
Old 09-05-2016, 12:12 PM
gjh
gjh's Avatar
Ye but get a welder ASAP, that stuff needs fresh metal, its coming on nicely with you, and don't worry, I'll be in the same boat as you with mine. Saving up to do mine, which hopefully will begin next spring. Keep up the good work.
cypressbill (09-05-2016)
Old 09-05-2016, 01:55 PM
cypressbill
knocked up a stencil for spraying my custom grill
Old 09-05-2016, 02:17 PM
cypressbill
i paid £150 for this engine, gearbox,loom,ecu key & ignition barrell
i could fit this myself but would need some paid help to wire it up and get it running as i wouldnt know where to begin.
but that job is a few months down the line as i am reconditioning, adding cams and port and polishing
Old 09-05-2016, 02:25 PM
cypressbill
there's only one way to learn and that's getting the spanners dirty. i had problems with my std 1.3 endura engine it kept stalling when coming to a standstill. i diagnosed as a dirty idle control valve quick spray with
and problem solved
Old 09-05-2016, 04:18 PM
cypressbill
3 coats of 2k clear on both bumpers done
Old 09-05-2016, 05:52 PM
cypressbill
my spoiler £12 ebay
dunno if im gonna respray as might be doing a blue carbon wrapped roof with welded plate over the sunroof
Old 09-05-2016, 06:41 PM
mk1turboestate
If your doing the plate over the sunroof yourself I wouldn't bother if you haven't welded before it will more than likely end up a mess as it's such a difficult panel
Old 09-05-2016, 06:53 PM
cypressbill
no i wont be dooing it.
Old 09-05-2016, 07:07 PM
cypressbill
i might buy a mot failure for pennies so i can practice cutting bits off and welding back on. plus swap out any parts i may need
Old 09-05-2016, 07:11 PM
cypressbill
at least if its a zetec ill be able to see how the loom is wired up
Old 09-05-2016, 08:11 PM
Shaun's
Shaun's's Avatar
Just my 2 pence.....but it might be easier to ask how to do things first instead of after you've bodged something.....don't get me wrong I've bodged plenty in the past but because I didn't have the wealth of the Internet...( I'm in my 40s ) everyone's here to help mate.
Old 11-05-2016, 04:44 AM
cypressbill
ok here's a question. whoever changed the sparkplugs or what ever has rounded off some of these alllen bolts from the engine cover. any tips on how to get these out?
obviously i would normally just drill them out with a left handed drillbit but there must be another way
Old 11-05-2016, 05:29 AM
cypressbill
here's a good example of my idea for custom lights. what do you think ??
Quick Reply: Fiesta mk4 project
