WRC2 Escort Cosworth
Old 07-09-2015, 02:34 PM
jessie_rs
jessie_rs's Avatar
Default WRC2 Escort Cosworth
Havent really added anything on this one but had this for months now. I used to complain and moan about the condition of the other one this ones even worse!
Some may know the car used to be an ex rallycross car previously built to group N spec. The car has been since converted to a circuit car.
Plans with it are to rebuild it paint it inside and out.
SPEC
ENGINE IS A CURRENT 2015 DIV1 JULIAN GODFREY RALLYCROSS ENGINE
10 LONG STUD,
WET LINERED NIKASIL CNC MACHINED BLOCK,
BILLET PISTONS,
STEEL HEAVY DUTY CRANKSHAFT WITH A BILLET DRY SUMP.
CNC FULLY PORTED HEAD WITH SPECIAL CAMSHAFTS.
INCONEL EXHAUST MANIFOLD,
MIS INLET MANIFOLD,
2015 SPEC TURBO WITH A 58MM RESTRICTOR,
PECTEL SQ6
MAPPED currently on 102 Superflow dev2 turbo ultimate race fuel
FULLY ADJUSTABLE
BLADED ANTI ROLL BARS
OHLINS REMOTE RESERVOIR COILOVER RACE SUSPENSION
HARVEY 6 DEGREE REAR BEAM
GEARBOX IS THE LATEST QBE87G 6 SPEED SEQUENTIAL WITH FLAT SHIFT
SHELL FULLY LIGHTENED KEVLAR DOORS, FRONT WINGS, REAR QUARTERS AND BONNET.
BATTERED
BRUISED AND NEEDING SOME LOVE
UNDERSIDE IS PRETTIER THAN THE TOP
Old 07-09-2015, 02:36 PM
jessie_rs
jessie_rs's Avatar
Old 07-09-2015, 02:38 PM
jessie_rs
jessie_rs's Avatar
First outing as always never too successful
Old 07-09-2015, 03:58 PM
Cool track toy. How many do you have ha ha.
Shame about the fooked shaft.
Old 07-09-2015, 05:07 PM
XRT_si
XRT_si's Avatar
Proper spec car that!
Old 07-09-2015, 07:29 PM
Joe Grp4 Escort
Joe Grp4 Escort's Avatar
Awesome spec
Old 08-09-2015, 03:40 PM
IainRS1700T
IainRS1700T's Avatar
Wow, was gonna say that must shift, but looking at that shaft, I guess not all the time!
What sort of numbers are you talking there - rally cross is anything goes isn't it?
Iain
Old 08-09-2015, 04:21 PM
jessie_rs
jessie_rs's Avatar
Yes so I cant really say! I will post up details of the engine dyno numbers
Old 17-11-2015, 09:54 AM
jessie_rs
jessie_rs's Avatar
De stickered the car
Old 17-11-2015, 09:55 AM
jessie_rs
jessie_rs's Avatar
Then one outing wasn't too successful
Old 17-11-2015, 09:57 AM
jessie_rs
jessie_rs's Avatar
Kevlar rear bumper ripped off and dented, along with front bumper and a few more wounds to add to it.
Rear panel pushed back out just for now and some of my classic repairs
Old 17-11-2015, 09:59 AM
jessie_rs
jessie_rs's Avatar
New front end added but nothing matches colourwise
Old 17-11-2015, 10:05 AM
jessie_rs
jessie_rs's Avatar
Last outing at Brands.
Struggled to heat up the tyres early on then checked I had 35psi in them so dropped 10psi out of them. Need a steep learning curve really to get this competitive again.
Old 17-11-2015, 10:07 AM
JK12
JK12's Avatar
like it! bet it sounds great!
Old 17-11-2015, 11:46 AM
tbtstt
tbtstt's Avatar
Just discovered your two threads: two seriously cool EscCos you have! Is this car the Escort Pat Doran ran years ago?
Old 17-11-2015, 04:43 PM
c20tbo
c20tbo's Avatar
Dont think it was pat's his was a gen WRC shell once rallied by Mr Sainz, Well spec'd car non the less, what diffs? also i thought current spec yb for JG would have ran a Tibuc inlet?
Old 17-11-2015, 06:41 PM
jessie_rs
jessie_rs's Avatar
No wasnt a pat doran car. I think it was andy grants ex rallycross car.
GT grippers front and back. Yes thats the only thing it hasnt got being an individual throttle bodied inlet it didnt comply to the race regs it used to race in. Quite a few of the rallycross boys are changing back to mis inlets. The mag MIS inlets produce more bhp whereas the tibuc make higher torque.
Old 18-11-2015, 08:14 AM
tbtstt
tbtstt's Avatar
Cheers for the info chaps! I've not seen much in print about any of the rallycross EscCos, so I'm always keen to learn more where I can.
Old 18-02-2016, 01:44 PM
jessie_rs
jessie_rs's Avatar
Some previous pics of the car:
File Type: jpg
File Type: jpg
Old 18-02-2016, 01:48 PM
jessie_rs
jessie_rs's Avatar
jessie_rs
jessie_rs's Avatar
Old 18-02-2016, 01:49 PM
jessie_rs
jessie_rs's Avatar
The last time I had it out at brands hatch
Old 18-02-2016, 01:50 PM
jessie_rs
jessie_rs's Avatar
the cars currently with crazycage getting some fab work done
Old 18-02-2016, 04:43 PM
sturat
sturat's Avatar
What race series is that?? Wouldn't mind going to watch that
Old 19-02-2016, 09:34 AM
wes
wes's Avatar
Its the QMN Saloon car championship, most races are at Brands Hatch
Old 23-02-2016, 03:49 PM
wes
wes's Avatar
If you skip to around 3:20 of this video, you can see how fast this car can be, the way it accelerates away from Rod Birley's escort on the start was awesome to watch, shame the propshaft came undone and it didn't make it round 1 lap
Old 23-02-2016, 07:00 PM
Cool pics. I like the ones with the flames coming out the exhaust.
What happened when there was fire coming out of the bonnet.
Old 23-02-2016, 08:49 PM
Billy_RS
Billy_RS's Avatar
Proper engine spec
Old 10-03-2016, 01:53 PM
jessie_rs
jessie_rs's Avatar
on its old engine spec when it threw a rod through its block.
Old 25-03-2016, 10:15 PM
jessie_rs
jessie_rs's Avatar
The car went up to crazy cage to have the exhaust moved from the passenger seat.
A little pic of the underside
Size:  280.6 KBName:  IMG_1918_zps3dv6b5a1.jpg
New floorpan
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 25-03-2016, 10:18 PM
jessie_rs
jessie_rs's Avatar
Some additions to the cage more for just aesthetics
Old 25-03-2016, 10:24 PM
jessie_rs
jessie_rs's Avatar
The freshen up started
Old 25-03-2016, 10:29 PM
jessie_rs
jessie_rs's Avatar
Started to start to clean up the shell ready to go off to be painted. The inside had been painted with household paint so had to remove it and ended up taking the inside and engine bay back to bare metal
The engines gone off to Julian for a general check over and remap back onto 98 fuel.
A new arrival:
Old 25-03-2016, 10:49 PM
cos elle
cos elle's Avatar
Where did you get the new escos floor pan from cheers
Old 25-03-2016, 10:57 PM
Nice one Tim
Old 06-04-2016, 10:29 PM
jessie_rs
jessie_rs's Avatar
Back from a paint freshen up
Old 06-04-2016, 10:30 PM
jessie_rs
jessie_rs's Avatar
Old 18-05-2016, 07:01 PM
JonnyBravo
JonnyBravo's Avatar
Looking a little better now, good to see the old pics of Dales, his car looks somewhat different these days !
Will you be coming out in the QMN with us this year ? could do with some more cars in the mix !
Old 18-05-2016, 11:56 PM
stu21t
stu21t's Avatar
What car do you drive in the qmn? 2 of my mates run e36 M3s in it.
Old 19-05-2016, 07:59 AM
JonnyBravo
JonnyBravo's Avatar
I don't race personally. We built Dales Impreza to the new spec and run that in both the QMN and Classic Thunder
Quick Reply: WRC2 Escort Cosworth
