New project st170 track car
#41
#43
So took car to ford fair first real trip out in it couples days before going thought take it for little drive make sure everything was ok , found out never bye a cheap quicks realise steering boss felt awful thought the thing was going to snap off
So took it straight off replaced it with a better more expensive but qualitty kit
#46
Looks great, coming along really well
romfordrst88 (19-08-2015)
#48
Oh loving the vents and SO want to do this to mine was it easy ?
PaulinhoT (31-08-2015)
#54
Few noob questions but what is the purpose of the roof scoop? Does it increase air pressure inside the cabin and create downforce? And where is the most correct place to fit bonnet vents so they're most effective? (Without the obvious 'on the bonnet' )
#57
The scoop is to let air in to the car as you don't get much from the slider on the polycarbonate windows, vents where mounted there as I've still got bonnet resses with clips to be fitted , I got the battery holder from eBay and the 250amp breaker
#61
Not much been done on it at the moment putting new Lower front arms on this weekend ready for track day on 2ndnovember at brands hatch , got few plans looking at few more carbon bits and starting shopping list for new engine
#65
There should be few good bits in the pipe line , do change front arms and haven't really looked at the engine to much I had a small oil leak so I replaced the rocker cover but couple weeks went bye and still had a leak and didn't have a proper look but on closer inspection the sump was fucked lol so wiped that of and fitted a new one not genuine as only to get me out of trouble for little while
#69
All looking really good
#71
It went really well handles good on corners just needs a bit more on the straights I'm looking in to things at the moment and a cnc head with new cams and fuel pump upgrade is what I've got in mind and a lighten flywheel to get rid of the dual mass crap
#74
Little update on the car haven't been on here while few things have changed I've change battery to smaller gel one and fitted a d-cat and new exhaust all the way through , all just ordere some bits which should be good for track
#75
"Some bits" sounds interesting
#76
Mfactory lsd ,+ more
I've bought a m factory lsd also a solide flywheel and a stage two clutch is on its way going to get it all fitted ready for Combe and if thing go to plane head will be machined and on
#77
Now that does sound good should make a huge difference
#79
Oh a nice update interested in the turbo route
