Rwd Puma Cosworth Track/road/show car - Finished project pics added
Old 27-05-2015, 01:24 PM
reese646
reese646's Avatar
Default Rwd Puma Cosworth Track/road/show car - Finished project pics added
Well some of you will remember this car up for sale a year or so ago as an unfinished project which the guy I work with was selling, well in the end I bought it off him with a view to finishing it, showing it this year and selling it on as I'm 6'4 and its a bit small for me. So as its nearly finished I thought I'd dig out everything I've got regarding the build which has spanned about 10 years and share through till it being finished.
Some of these photo's are really old so sorry about the scan quality.
Car originally started life as a 1.4 puma, was only 2 years old with 23k on the clock and had had a front end smash, this has been a bonus as its been dry stored for the last 10 years so the shells immaculate. These pics show mainly the initial work getting the kit fitted, cage in, and engine and drivetrain sorted out.
Will add more up to date pics shortly, but the car has changed alot since anyone last saw it.
Old 27-05-2015, 01:59 PM
Caddyshack
Caddyshack's Avatar
Cool project, I will be keeping an eye on this one. Keep the pics and updates coming.
Old 27-05-2015, 04:08 PM
reese646
reese646's Avatar
Haven't got many more on this computer, just a few of the underside when I bought it.
Old 28-05-2015, 08:33 PM
Very cool matey. There can't be many cossied pumas about.
Old 29-05-2015, 07:16 AM
COLEYST200
COLEYST200's Avatar
It will be nice to see this car finished
Old 19-06-2015, 08:57 AM
reese646
reese646's Avatar
Right just got back off holiday and forgot i left the thread without proper pics, so this was the car as I got it, completely yellow, not what I had in mind for it, with horrible alloys and no dash, plus running lumpy as hell.
Old 19-06-2015, 03:50 PM
Thats looking well. It wants lowering though lol.
Old 19-06-2015, 04:29 PM
reese646
reese646's Avatar
thats to come Glenn, cheers.
First i needed to put my stamp on it and get it brightened up abit, so it needed respraying, got a design sorted out and set about it, its three different colours, the yellow is rover trophy yello, the light blue is BMW Santorini blue from the I8 and M3/M4 2014 and the dark blue metallic was a bit harder to figure its 2014 Mustang Kona Blue and looks amazing in the sun, contrasts well against the flat Santorini blue, over all very happy with how it turned out.
Old 19-06-2015, 05:14 PM
Caddyshack
Caddyshack's Avatar
That rear shot looks very mean and cool. I would like it all in that light blue to show the bulgy shape more.
Old 19-06-2015, 06:32 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Jesus those wheels are horrendous lol.
Old 20-06-2015, 09:22 AM
reese646
reese646's Avatar
Yep the wheels are horrendous, all the guy I bought it off could get with the right offset just to get it rolling.....
But had these ordered to size with the rears having a ET11 offset, still needs spacing though lol, back end is stupidly wide
As well as custom suspension made by GAZ all round, which I have to say was a fantastic service, to literally whatever I wanted, and the price was more than reasonable I thought.
Old 20-06-2015, 09:24 AM
reese646
reese646's Avatar
Fronts are based on 2wd cosworth, just 45mm shorter, but threaded all the way, car will bottom out before you run out of adjustment, rear end was completely made to spec for the puma with the help of the guys at GAZ.
Old 20-06-2015, 10:31 AM
reese646
reese646's Avatar
And last update for today, these will be going on, Front 4-pot Brembo calipers off of an EVO-8, mated to a focus rs 13" discs, I've made a custom billet adapter plate at my friends machine shop to fit it, used to have this setup on my mk6 rs2000 and worked well.
Old 20-06-2015, 11:44 AM
jontysafe
jontysafe's Avatar
Nice project and kudos to you for doing what you want with the paint job!!!!! Very Hot Wheels.
Old 23-06-2015, 07:35 AM
reese646
reese646's Avatar
Thanks, the paint will go with the livery that's gone onto the car, it will all start coming together shortly
Old 23-06-2015, 08:21 AM
reese646
reese646's Avatar
few pics with the new wheels on
Old 23-06-2015, 11:27 AM
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
THe paintscheme looks really cool!
Old 23-06-2015, 04:04 PM
Caddyshack
Caddyshack's Avatar
Those wheels make a huge improvement.
Old 24-06-2015, 04:56 PM
reese646
reese646's Avatar
Thanks, the paint job as I said will make a lot more sense when you see it finished.
Anyway, the wiring loom needed doing so I decided that I wanted a modular dash, no shitty little fuseboxes stuffed here and there, saw something similair on a pikes peak rs200.
Basically built from scratch, you can remove the whole dashboard with the wiring loom in situ, there are plugs both ends to detach it. Glass fuses in an aluminium face, every joint soldered, including kill switch and battery gauge. took me about 30 hrs and was a mission and half. not the best pics but you get the idea.
Old 24-06-2015, 05:41 PM
It looks well with the wheels on.
Old 25-06-2015, 06:37 PM
lee2cossies
lee2cossies's Avatar
Good work nice to see this getting done, iv seen it a few times in the past when iv called into the scrapyard in bargoed.
Old 26-06-2015, 08:14 AM
reese646
reese646's Avatar
Thanks lads, nice to get some input as the threads been a bit quiet which is a shame, but anyway here's a pic of the dashboard fitted, got a full set of Smiths gauges and sensors to run them as well as a wideband AFR by innovate. changed the turbo back to a T3 as the T34 needs the seals doing, also fitted a new 2 bar Map sensor, group A coil and new leads as well as a new air temp and coolant temp sensor. Fitted the brakes with new pads and discs, more updates soon.
Old 26-06-2015, 09:10 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
You are making good progress on it mate, keep it up.
Old 29-06-2015, 08:29 AM
reese646
reese646's Avatar
Cheers, I was going to get a company in to do the sticker work, but after pricing it up I thought sod it I'll do it myself, so bought about Ł70 worth of vinyl off ebay and set about it with a scalpel lol, results we're actually pretty bloody good, here's a look at what's coming.
Old 01-07-2015, 08:20 AM
reese646
reese646's Avatar
Front splitter fitted, rear spoiler pics to come
Old 04-07-2015, 10:10 AM
reese646
reese646's Avatar
well I'm guessing this isn't everyones cup of tea as its not really attracted much interest, so as the cars finished I'm just going to post all the finished pics, hope you enjoy them, its been a great project to work on, a bit different these days and finished to as good a standard as I can manage.
Old 04-07-2015, 10:28 AM
Ali_B
Ali_B's Avatar
I love it , always liked Pumas !
Any engine bay shots ?
Old 04-07-2015, 10:30 AM
reese646
reese646's Avatar
Rolling road as its road legal, MOT'd and run well
Old 04-07-2015, 11:34 AM
Vicar
Vicar's Avatar
I actually really like that, didn't like the paint scheme but with the decals it brings it to life!
Old 04-07-2015, 12:12 PM
jontysafe
jontysafe's Avatar
Default Puma
Great job, now it makes sense! I hope Red Bull are paying you?!
Old 04-07-2015, 12:39 PM
M K
M K's Avatar
Looks much better with the decals
Great work, love it
Old 04-07-2015, 01:15 PM
reese646
reese646's Avatar
Was always getting stickered this way, glad its getting some love, I'm really pleased with how it turned out as it took alot of hours to do everything myself when it would of been easier to let someone else do it. cheers lads
Old 04-07-2015, 04:16 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Well done mate, looks so much better than when it was just yellow.
Whats next, just use it?
Old 04-07-2015, 11:44 PM
stu20004x4
mk6 escort fantasist
stu20004x4's Avatar
Pucker build! You still selling it?
Old 05-07-2015, 11:40 AM
robp-tt
ZETEC TURBO
robp-tt's Avatar
I really like that. Paint job looked good on its own but looks even better with the stickers.
Whats next with the car?
Old 05-07-2015, 11:55 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Dose look good with the stickers on it mate I like it!
Old 05-07-2015, 05:42 PM
lee2cossies
Looks great fair play much better. I spy tinkers rs500 in the one photo too!
Old 05-07-2015, 05:54 PM
tracktoy
tracktoy's Avatar
looking good Al, nice to see it out and about
Old 05-07-2015, 06:23 PM
Thats stunning. You have done a really good job of that.
Old 05-07-2015, 10:52 PM
reese646
reese646's Avatar
Thanks a lot lads, as said I'm really happy with it, but yeah it will be going some time over the summer to fund the escorts wrc project, like I said it's too small but I have grown pretty attached to it, will be a shame to see it go
Quick Reply: Rwd Puma Cosworth Track/road/show car - Finished project pics added
