Smokestone 4wd Cosworth Sierra (Greece)
Hello my name is Mitsos along with my brother Takis we run a little garage in order to build cosworths in our free time, this car is my brothers 4wd smokestone cosworth sierra. It was a stock car now we made some upgrades all the work is carried by us. Thanks for watching!
200 block
polished and balanced crank
cometic gasket
t34 turbo
bigger sump
3bar map
l8 ecu with msd wasted spark, als and lc
air injectors
airtec inlet
ap 4 paddle clutch & plate
lightened flywheel
siemens injectors
044 pump
diy turbocooler
datsun radiator
pace intercooler
saab oilcooler
diy quickshift
bilstein front coilovers, avo rear, diy 6 degree beam
front and rear escort cosworth anti roll bars
_DSC3102 by wyriwys, on Flickr
_DSC3107 by wyriwys, on Flickr
coilpack
_DSC3109 by wyriwys, on Flickr
saab oil cooler
_DSC3112 by wyriwys, on Flickr
fixed the wiring for a cleaner look
_DSC3114 by wyriwys, on Flickr
radiator fans relays
_DSC3115 by wyriwys, on Flickr
_DSC3116 by wyriwys, on Flickr
als and launch control switches, launch control has a switch on the clutch pedal so it turns off when the car starts to move
_DSC3117 by wyriwys, on Flickr
6 degree rear beam
_DSC3121 by wyriwys, on Flickr
_DSC3122 by wyriwys, on Flickr
bigger sump
_DSC3127 by wyriwys, on Flickr
clean look inlet we mounted the wiring on the down side of the inlet
_DSC3129 by wyriwys, on Flickr
we made a bigger airbox from sheet metal and drill holes on the airbox and painted flat black
_DSC3131 by wyriwys, on Flickr
air injectors and a turbocooler we made from a bmw radiator
_DSC3133 by wyriwys, on Flickr
we made and quickshift faster than the aftermarket ones and the we made the tower higher so the selector sits straights, now the changes are very close.
_DSC3134 by wyriwys, on Flickr
l8 ecu
_DSC3136 by wyriwys, on Flickr
200 block
cometic gasket
t34 turbo
bigger sump
3bar map
air injectors
airtec inlet
lightened flywheel
siemens injectors
044 pump
diy turbocooler
datsun radiator
pace intercooler
saab oilcooler
diy quickshift
coilpack
saab oil cooler
6 degree rear beam
bigger sump
l8 ecu
Very nice mate any pictures of the cars?
smiley (27-03-2015)
_DSC3149 by wyriwys, on Flickr
_DSC3159 by wyriwys, on Flickr
_DSC3162 by wyriwys, on Flickr
_DSC3163 by wyriwys, on Flickr
_DSC3164 by wyriwys, on Flickr
Our next builds
_DSC3167 by wyriwys, on Flickr
_DSC3168 by wyriwys, on Flickr
Group N escort restoration coming soon it will run on hillclimb events
_DSC3138 by wyriwys, on Flickr
Our next builds
smiley (27-03-2015)
Kool i like the greek style you love big power welcome to passionford mitsos
smiley (27-03-2015)
The big problem in Greece is traffic+heat+standard radiator wiring and relays etc. That's a prescription for overheating, so in summer its better to drive you cossie at night in open streets. Turbocoolers is a must also because the water coming from turbo is very hot and we have to address that. But we dont have a major problem that i see you have in UK, RUST we dont have rust here, you will have to leave the car in to a pond to have rust!
A radiator (i think it was fiat), i cut the core i wanted the tig welded the side water chambers and two bolts for inlet and outlet, then i pressure tested it. I havent test the inlet outlet cº difference yet
A pro alloy rad, is a work of art but not cheap! Anyway i dont really have big problems with this engine, a bigger spec one will have to have a big modern rad.
Mitsos (13-04-2015)
RB26DETT
17
27-05-2016 11:26 AM
