MA Developments Sapphire Cosworth 600+ HP 4x4
#204
You need e85 proof fuel lines don’t you?
I bet that isn’t a cheap fill up? My Rangie was Ł128 last fill up with diesel and that was not the super wow stuff. I get 30 to the gallon on 4.4 v8 twin turbo.
#208
Fuel is 102 RON like Marks says.. it's about Ł1,77 pound for 1 liter at the pump..
It's from TTV Racing UK mate.. I have a spare lightweight flywheel over here which I got from Martin a while ago, the same which is on his site if you're looking for one?
#211
at the moment the clutch is fitted, recalculated the new position of the hydraulic center clutch bearing and made a strong frame so that I could already feel the pedal, and see what travel the clutch bearing makes before the plates are 'free'
With this there is no need to fit the gearbox which makes it alot easier to make adjustments
The nose piece from the gearbox also has some adjustments for the new position of the clutch bearing
Gearbox out
Old clutch/flywheel
Some adjustments on the milling machine for the gearbox nose piece
New clutch fitted
Gearbox out
Old clutch/flywheel
New clutch fitted
#212
Nice! Competition102! I baught barrels of them, i don't know if the quality from the pump is the same but top up with some octane booster anyway.
You have the ignition map also tweaked by Mark for 102?
#213
I mapped it on the 102 but kept it safe as high inlet and we was at the power he was happy with. Probably another 50hp in that’s package.
Mark
Mark V8 (26-11-2018)
#216
Great launch
#217
Any issues with it jumping out of gear?
#218
Yes remember spoke to sombody else having this problem and it's not the fork
#221
Good to know mate
lukeeboy149
22-08-2015 04:29 PM
