WRC1 Escort Cosworth some new bits
#89
Yeah a little annoying still haven't even really been able to use the car properly yet and the engines gone bang.
The 200 block is on a 0.5mm overbore so some more positives.
Found some comical bodges on the engine can only assume they were there before. I don't understand why the previous chap spent big money on a Harvey engine and then finished it with whatever they had lying around! Some stupid bodges
#90
#93
Engine was dropped off to Harveys a little while ago and hes reported good news. Hes managed to salvage the block so it doesn't have to be bored to a 1mm or be nikasil linered which was the other option.
Recently got suckered into all this borg worner hype and bought a twin scroll tubular manifold, 300sx turbo and ext wastegate with a couple of hundred miles on it which now ive found out is far too big for what I needed. Ummed and arghed on working the engine to suit but cant justify it really. I was happy with it beforehand so just going to change exhaust housing to a 76 for a little more.
#95
Nothing to new the engines with SCS. Ended up changing the spec a little bit and will have a twin scroll tubular manifold, a new 7670 efr turbo and an AS inlet. Jimbos having a little play with cams and see what it will do!
#96
Sounds good mate, looking forward to seeing it built back up
Fullflush (16-02-2016)
#102
Fantastic looking car
Top mounts look seriously heavy duty. Not that I'm after some, but out of curiousity who made them?
#107
I remember seeing this at brands that day, car was looking awesome round the track buddy.
What power was it on the old setup?
And with what turbo?
Cheers Paul
Cheers Paul
#108
They have done quite a few they had 4 engines in at the same time having efr fitted. It seems everyones going that way. I thought that initially also I dont know who started all that down our way.
#109
looked ok but drove pretty poorly suspension set up has been all over the place. It was on a gt30 450+ something like that
turbotrev (01-03-2016)
#111
What's your engine spec mate.
