Zetec turbo help
Zetec turbo help
Hi all after abit of advice building a 2.1 zetec turbo but abit stuck for management I was going to go OFAC but now have read that it might not be right for what I need is there anything out there to suit my needs thanks.
What's wrong with the ofac set up for you? What car is it in? Iv bought. OFAM ecu which is megasquirt basically but plugs straight into a ofac/ofab wiring loom so less head aches
I did look at a ofam ecu a while ago but not herd anything about them on here, I do have everything needed for ofac including ecu put I've read I will be limited to the performance because of the boost. Will a ofam ecu sort this?
