mk3.5 fiesta sapphire 1.3!! Want to convert!!?
Old 29-12-2014, 09:47 AM
liamT74
liamT74's Avatar
Default mk3.5 fiesta sapphire 1.3!! Want to convert!!?
Hi yea I'm quite new to forums so here goes anyway, I just bought a mk3.5 sapphire 1.3 (not carbed) and basically I would like to run it with a puma lump and I'd like some info on how I can go about doing it like parts, changes and other stuff etc. If someone could help ix appreciate it
Old 29-12-2014, 10:18 AM
chris cdti
chris cdti's Avatar
Easier using the RS1800 or 2.0 Zetec engine in a mk3.5 using the mountings and loom etc from a 1600 SI
Old 29-12-2014, 10:34 AM
liamT74
liamT74's Avatar
What I was thinking about with the puma is that I could easily pick one up, I'm assuming that with with the rs1800 and the 2.0l I'll need a range of parts, what I'm hoping for is just an in sight to what steps I'd need to follow for the conversion
Old 29-12-2014, 11:08 AM
chris cdti
chris cdti's Avatar
The mk3.5 fiesta never had the 1250/1400/1600/1700 zetec Se engines fitted into them as they got fitted into the mk4 fiesta "96" onwards cars. So you would have to do a bit of messing about to get it fitted in and working unlike a mk4 that's more or less plug and play.
Personally if I had a good mk3.5 shell I would be buying a rotten Fiesta SI 1600 as this will have everything you will want, looms, fuel tank and pump, subframe with power steering brakes, rear bean with anti roll bar etc and even a body kit if you wanted to use it.
Old 29-12-2014, 04:34 PM
Smidydevil
Smidydevil's Avatar
Go on fiestaturbo.com engine conversions have been done plenty of times on there using a puma lump is going to be big hassle for no reason, stick to a 1.8/2l zetec e engine will drop straight in cvh or zetec mounts will fit it into the car use your current gearbox as that'l be a ib5 unit being a mk3.5 and then engine loom and ecu will plug straight in off a si and a 2l ecu will give you the 130bhp map
Old 29-12-2014, 08:25 PM
liamT74
liamT74's Avatar
Ok guys cheers, I'll do some more research and get creative lol
Prickly_buzz
07-12-2017 09:52 PM
tib2220
14-09-2015 12:33 PM
Maxwell
Fiesta ST
13-09-2015 05:31 PM
Neil Clark
08-09-2015 07:06 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: mk3.5 fiesta sapphire 1.3!! Want to convert!!?
