hi, could anyone tell me how to remove the drivers side front drive shaft. there is a bit with two teeth on which is held in by a bolt, but when i remove this it still wont pull out, what am i doing wrong.
Drivers side one you need to remove the front diff cover on the bottom as theres a circlip inside the diff on the end of the driveshaft which stops it from being pulled out
As said, remove diff cover, there is a circlip holding it in.
That thing with the 2 teeth is to hold the bearing cup in place on the diff housing nothing to do with the shaft
