My New M.A.D Escort Cosworth
#321
Thats good news the display is working
Not given it any in 1st just use it to get me rolling not check to see what revs drop to between gears as to busy concentrating on the road. Mark will be the best guy to ask as he will have logs from mapping.
Standard Rear diff with 7" rear axel 3.9 crown wheel & pinion.
Wheel are 18s with 240/40/18 tyres
At 3k rpm im doing 60 mph in 5th gear. As for top end clocks only read 140 mph with the bigger wheels it should be doing around 160/165 mph. It gets there quick enough.
Yes on that basis 8k rpm should be 160 mph. I guess on that basis mine will be about 140mph / 150 mph which is what Romain originally thought although Bara says this is sometimes a bit of a guess.
#323
Happily retired
Give my regards to Tim & his lovely Wife. He's just down the road from me, mention 850bhp & White Sierra & he will know me. He filled my Nitrous bottles back in the day.
#324
**RS COSWORTH**
Last bits on the gauges done had the shift light setup which I tryed out weekend
#326
**RS COSWORTH**
The AP 6 paddle clutch will be getting replaced with a Helix 6 paddle coming spring with aload more Mods from M.A.D
#327
What's was peak boost and hold?
Can you refresh us on your spec cheers
Si
#328
**RS COSWORTH**
Peak boost was 2.3 bar holding 2.0 bar.
The engine spec is same as the 1st page.
800bhp (28-09-2016)
#330
**RS COSWORTH**
Emtron Ecu will be going on around April/May will have the wiring loom made from Mark before its fitted to the car
Bosch sensor for closed loop looking forward to having this fitted.
#331
Why moving from the Vipec?
#333
**RS COSWORTH**
My car was 1 of the first cars fitted with a aftermarket ecu. Has a Autronics SM2 fitted at the moment.
With the Autronic SM4 or Vipec I'd have to buy the knock control module separately.
You can't add knock control module on to SM2.
With the Emtron it comes with lot more options as standard. I may go mulity throttle bodies and the ECU will help if we decided to have this fitted.
I will wait and see have Rods car revs like and take it from there
#334
Thanks for the explanation
#335
Looking good mate used to the power already?
#336
**RS COSWORTH**
I know you'll get it perfect mate look forward to the end result my shell conversions finally been started
#338
**RS COSWORTH**
I've had time to prepare
#341
**RS COSWORTH**
**RS COSWORTH**
Features that will be going on the new ECU sensors will arrive with the new wiring loom.
Oil pressure
Fuel temp
Fuel pressure
EGT
May put a turbo speed sensor on aswel
May look it to getting white face Stack gauges fuel pressure and EGT fitted.
Oil pressure
Fuel temp
Fuel pressure
EGT
#344
Lovely car mate!
What power should it do with a decent clutch in it?
What made you go for the 7670 instead of the 7064?
Cheers Paul
Cheers Paul
#345
**RS COSWORTH**
It should see early 500s.
I'm on a 7064 I found it much nicer for part throttle driving and nicer over all below 3.5k than a 7670.
#346
I find mine quite brutal as it comes in very early and boosts so hard, it just takes off up the road in a very in unsocial way, do you find that keeping it pinned in 2 gears leads to some serious speed?
#347
**RS COSWORTH**
It don't hang around for sure going 2nd up wards in gears its very fast saying that you could be sat at 65ish in 5th and floor it it just picks ups and goes from 5th.
Having the shift lights makes it much more better as you can rev it right up and shift when the red light comes on. You go through the gears in no time.
#348
#349
**RS COSWORTH**
Other nice piece from Dave (Monster) gauge holder for 52mm Stack EGT & Fuel Pressure gauge to fit under the stereo.
#351
Wow, looks great, is it alloy?
800bhp (05-12-2016)
#352
**RS COSWORTH**
Yes alloy. Was thinking doing the writing in white & red but may look abit chavy.
#353
Might look good but I think subtle would match the colour of the car better.
#354
**RS COSWORTH**
Unmade wiring loom (this should be made up sometime before April) fuel temp, fuel pressure and oil pressure sensors.
Few bits remaining to get before new ECU gets fitted.
#355
I have been trying to find the contact for Dave (Monster) as I bought some "Powered by Cosworth" badges from him but now need some custom stuff done, can you post up or pm his details please.
THANKS JON FOC, I NOW HAVE IT ON YOUR TEXT
#356
**RS COSWORTH**
Pic I forgot to put up from last MOT in July
#357
Love this car....that integrale looks sweet too
800bhp (07-01-2017)
#358
**RS COSWORTH**
That's 1 car that looks really nice in yellow interior is lush aswel being wing back alcantara seats.
800bhp (11-01-2017)
#360
**RS COSWORTH**
Stack EGT & Fuel Pressure gauges arrived today.
