mondeo cosworth. MOT'D & TAXED
Paul_RS (15-11-2014)
Mark RS (13-11-2014)
Mark RS (15-11-2014)
#130
You've been busy!!! Looks great with you, The rack and subframe look spot on!
#131
few more things gathered up
thanks to mk motorsport for doing my turbo hanger welding is awesome
also got the solid rear beam mounts from him
got the start of my Aeroquip from torques on ebay I've decided to use black
got some of my new brake lines as well
the expensive stuff now
got my gearbox and diffs back from bara motorsport
gone for one of his front 7" diffs which is a copy of the old r and d
decide to go 3.9 drop gears on the car so when the cwp was getting changed I got the bearings and viscous redone when it was all in bits
I bought the gearbox second hand but as I was changing the cwp in the diff I needed the drop gears changed,turns out the box already had 3.9 drop gears so that's a result but the chain was slack so that was replaced and a few other bits done
turbo has been sent back as it was supplied wrong so hopefully that wont be long until its back
so all I need now is the car
Mark RS (19-11-2014)
#137
Nice looking car pal. Loving the little purple hoses, should compliment the other bits.
Mark RS (22-11-2014)
#142
#151
we started the build last got part of the wiring loom back through and decided to trace it back and see what was what,theres a lot of wires not used coming from fuse box so we've decide to trace them back and remove the as to the ends being tapped,takes a fucking age
got my new vin plate on thanks to monster
Mark RS (21-11-2014)
#156
Brings back memory's great car...first of its kind..in the 90"s
same as the green escort MK1 with a complete 4×4 undercarrage and ofcourse a cosworth engine... and the severnvalley ford transit van with i believe an rs 500 engine with 500 HP and the centerlock wheels....
But this one yup iconic......
#159
What an awesome project, really pleased to see this heading back out into the world. Think everyone thought I was a bit mad a few years back when I said I had a soft spot for the Mondy... this one is "The Don"!
