1987 Series 2 ERST Project
Hi Guys, first post on here! Recently I have purchased a radiant red 1987 Escort RS Turbo. Looking to restore her to her former glory. At first glance the first few problems/niggles noticed were:
Dented bonnet
Bonnet release mechanism not working
Rusty rotten front panel
Wings require replacing
Drivers side sill needs replacing
Boot struts knackered
Modified bumper/radiator grill cut out
Temperature gauge not working.
Half the heater box missing
Clock cover snapped
clock surround clips broken.
Nothing too major at the minute. Pics of current state to follow.
Dented bonnet
Clock cover snapped
All the following should be here today/tomorrow:
Bonnet
90 spec front bumper
Bonnet cable and release mechanism
boot struts
Heater box with rubber seal
Service Parts
K&N (the existing one is bent and tired)
Fuel filter
Oil & filter
Magencor Leads
Plugs
distributor cap and arm
new temperature sender, fan switch and thermostat
Here are some pictures:
Bonnet
boot struts
Service Parts
Fuel filter
Oil & filter
Magencor Leads
Plugs
It isn't too bad really. Thought I'd sort out the little niggles and replace a few parts before she gets shipped off to the body Shop for repairs and respray in July.
RSmark84 Shame its Radiant red and not in the correct Rosso red colour.
Got most of the parts in. Can give her a good service this weekend and sort all the little (sortable) problems out.
Boot struts fitted:
Some of the parts that have arrived:
Should have more of an update after this weekend.
Yeah it isn't too bad to be honest. Looks like its been kept on a low budget so far. Some of the wiring is poor and the battery clamp has been replaced by a block of wood and accompanying rag. this will all be sorted eventually.
Yeah the chrome lettering will be off and replaced by the standard sticker.
Yeah I will eventually get a set. I'm waiting for the body shop to have a slot available so I can take the car there. I don't have a garage Need a new house.
While I'm waiting I'm just sorting a few problems out and giving it a service. The whole cooling system needed an overhaul also. The fan and temperature gauge wasn't working. I've replaced the thermostat, fan switch and fuses. I know the temp gauge works but its connected to a small sender within the top right radiator hose. Is this correct? I have replaced that sensor anyway. I also have a bigger one but not sure where it goes, front of block?? Also does the gauge get connected here instead?
I've replaced the bonnet now the whole mechanism/cable. The 90 spec bumper has also turned up.
Appreciate the help chaps!
I will take some pictures on Friday and fit the remaining parts.
temp gauge sender unit goes into head next to the exhaust manifold of stat hosing.
If you are looking for a full set of red samcos with near minimum use speak to me via pm.
thanks Mark,
PM Sent.
I think I've found the hole for it however no sensor is fitted which is strange. I have the new one anyway. Should coolant leak if there is no sensor. I'll take a picture of it tonight.
All parts fitted so far, pictures to follow, car is still running like a dog at the moment though. Will check it out this weekend.
PM Sent.
Sounds brilliant dude. Look forward to it
She's a beaut! yeah be good to have a glance over yours to see how everything should be after the shoddy wiring and botching that's taken place on mine over the years.
I'm always happy to help. I'm sure we can sort out your wiring aswell.
I can see plenty of missing parts you need to sort the car out so bring a notebook with you can we'll list down everything you need.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
SMILER258
28-09-2015 09:04 AM
