Series 1 Rs Turbo ...wheres my reverse ?
Hello,
Been lurking here for years and have nearly finished my s1 rebuild but along with a lot of other little niggles im having an issue with my gear selector...
Original S1 Gearbox but with uprated clutch , new clutch cable . ..selector set back in original place ( pretty sure it is )
Problem : When i try and get reverse ( push down , i assume ..its been sooo long!) the selector actually pops out of the bottom of the rubber 'donut' that holds it into the selector housing.. in short its a nightmare to get reverse ..if im really gentle i can caress it in bit its annoying ..the other gears are better but still a bit clunky. any tips or help would be greatly appreciated!! do i just need to set up the selector again ? is the the quadrant ? ?
Many thanks , Pete
ps i assume all that holds the selector mechanism up into the floor pan is the rubber donut in the brass plate thats bolted to the car?
Many thanks , Pete
thanks for the replies..
Cossie891 - are you 100% sure its not push down ? my memory is shocking its been off the road forever !
GeordieGooner - Cheers mate i will do when i get a minute
Ok so ive reset the linkage by loosening the 13mm bolt and pushing the selector on in the box all the way forward into reverse , could not get much of a clockwise turn on it tho .
i then got a buddy to hold the gear stick in 'reverse' and did up the bolt.. its still a bit clunky but its 100% Push Down for reverse .. any comment ? its a C plate s1 escort
ok.. any suggestions on whats fucked / how to set it up better ? like i say the shaft on the box goes all the way in when i put a screw driver through it but its only turns a very slight amount in a clockwise direction ( read this in a guide somewhere on here ).. stumped...
ok thankyou for your patience .. ill try that. how far should the shaft turn ? to clarify ..in your method you don't actually push the selector into the box before doing up the bolt (theres another guide on here that says to do it that way) .
sorry to be a pain
sorry to be a pain
..and yes its the original linkage that was on the car when i got it..the only thing thats changed is the clutch / new clutch cable but that shouldnt affect setting it up i believe
yep thats right . dont think im getting enough twist though..when i tried it early today the shaft in the gearbox barely moved in a clockwise direction .. but slides in and out ok
