Mk4 Fiesta Puma Conversion
#43
so i managed to get it all working and running the fuel pump working but the problem is now the wipers dont work and when i put full beam on the indicator light comes on dip works as normal, and the indicators just refuse to work
#58
You should have took pictures of where every thing went.That big plug you have in the pic even I don't have one of them.Have a look at the wires properly the wires can only stretch so far and can only plug in one place
#59
Update
SOO got the car on the road but the lights and wipers are not working properly something in the wiring or fuses is seriously fucked but ill sort it out.
#62
any ideas how you move the massive heater matrix thing thats under the dash, i have already got the dash out again to tidy some things up.
#65
Tidy Up Time
Right its time to sort my car out, i have a budget of Ł2k and with that i would like to sort out the suspension, drive train, engine and other acc's.
Suspension -
Im not sure weather to buy a full shock and spring set off ebay for Ł200 or just buy some lowering springs, im looking for a stiffer ride, something that will stop the body roll.
Engine -
Right im getting the cam cover custom re built free of charge, possible upgrading the cams, im getting some hi spec HT leads, new water pump, replacing all gaskets, re building the inlet manifold with all new parts
Brakes -
Im going to re build the rear standard brakes and im going to put puma calipers on the front with drilled and grooved discs, im going to remove the brake master cylinder and put a pedal box in, run new braided lines to front and rear brakes with a hydro handbrake.
Fuel -
Im going replace the fuel pump with a new one and run new fuel lines to the fuel rail and put a fuel pressure regulator in.
Drivetrain -
New drive shafts, rebuild subframe with new bushes, re build rear axle with new bushes
Anything else i should have a look at??
will be starting on it in a few weeks
Suspension -
Engine -
Brakes -
Fuel -
Drivetrain -
#70
if so its the wiper stalkers! I don't care what anyone says there not inter changeable! I tried mk4 digi mk5 digi and nothing, fitted puma digi problem sloved!
#71
#72
Alot of that stuff not needed.
suspension.
full polybush kit. Road gmax springs and shocks track gmax springs and spax shocks. Front lower strut brace and rear.
brakes-
replace drums with new parts there fine the size thay are. Brakes some 300mm setup.
wheels and tyres-
some 15s with good rubber
engine-
full serivce and exhuast manifold and cat back exhuast.
and that will pritty much be the whole car done and good for miles to come with change if you sorcue some of them second hand.
suspension.
brakes-
wheels and tyres-
engine-
#76
Just as well as your current interior loom will but if you want the easiest buy a 1.7 loom so then you only have the tail lights to play with.
#77
Spring Cleaning
Right so after having the lower arm ball joint drop out on me i decided it was time to replace some parts so here goes...
took the motor out for a clean and to get the inlet manifold rebuilt
the mess so far will be cleaing it all up tomorrow hopefully
painting up what i can tomorrow
small collection of new bits i have to go back on
Wheels and inlet manifold done, get the center caps done for the steelies now
can any one give me any pointers on removing the petrol tank?
#79
right i dont have a f#####g clue what has gone wrong but here goes, i put the engine back (puma 1.7) in plumed it all up filled it up with oil and water and the started it (i primed it a few times first) it ran sweet as a nut for about 10 secnds then cut out since then 2 days ago i have not been able to get it to fire, we have new plugs, plenty of spark, we have compresion, fuel in the cylinders, turns over fine just will not fire!!
when i have the engine out it was jetted off and left to dry in the sun for a few days, i replaced the fuel lines with some 8mm braided fuel line, new lambda sensor new tps new idle control valve, new maf
fuel is definatley coming through just cant for the life of me figure out what is causing this, stripped the whole injection system and intake manifold and checked everything
i have the intake manifold and engine mounts powder coated could that cause this, like no earth or something?
