Supercharged Zetec Anglia
right guys last year I was asking what people thought on here about supercharging a 1800rs zetec in my 100e Anglia.i got fed up of running 16 second 1/4 miles and just got on with it ha, a mate had a m45 eaton laying about so I picked that up on a Saturday afternoon and by Sunday all I needed was a bit of neater and more sufficient pipe work making up, and a longer belt for it to run!
I ran it for a couple of weekends on standard ford ecu but just cranked the fuel pressure up and run it really rich, knocked a second off the personal best straight away,
Then after speaking to Rob and Boostmonkeys I bit the bullet and got an OFAM ecu off him and straight away it got me down into the 14s on a base map! Had a few fiddles with the mapping and now running 14.4 without a proper set up and quite low boost!
Over winter I'm sticking a bigger bottom pulley back on to bring the boost up again and sticking some nitrous through it! I'm still in need of a proper rolling road set up so I'm hoping big things this year as long as it all holds together!
Use a hosting site like photobucket. Once uploaded it will have some codes to share the pic. It's the IMG code you want, copy that and then paste in this thread and it will show the picture. Needs doing for each photo mate.
Air temp is pretty high on the road, when I race t isn't too bad as the charger doesn't get a lot of abuse for a long period, next mod will be to tube the front end so I can re route the charge pipes so that I can have a Fmic and water meth to cool the air temps, obviously money's the big issue here so it's not going to be that soon though
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
