Escort Cosworth Monte 087 resto
#41
Monte 087
Cheers for all the positive comments
Some more pics
Carbon rear dust shields made by Karl they look amazing in the flesh
Front hubs were blasted & painted then rebuilt with new Ford bearings & seals
Bolted the rear diff into the rear beam & fitted it to the car, every single clip replaced with new, fuel lines painted & refitted
New Ford fuel filter, bracket & some plastic fuel lines fitted. Powerflex rear ARB bushes
Some more pics
#46
Monte 087
New front Koni struts, Ahmed springs & all new strut top bearings, bushes etc from Ford
Built up
Rears & new ARB drop links
Rear arms, hub assemblies built up with new Ford bearings, carbon fibre shit shields & struts fitted
Rear roll bar fitted
Bulkhead to be drilled for hydraulic clutch conversion
Marked off and drilled, nearly cried doing this to my nicely painted shell lol
Pedal box removed to be modified for the clutch conversion
Couple of holes drilled, & some brackets removed, sent all the bits off to get powder coated, new bushes & pedal rubbers
Built back up
Been looking for years for a new bulkhead sound deadening pad but have never found one or heard of one ever turning up so gave up and made my own
ABS block fitted with the bulkhead brake pipes, every clip renewed
Servo etc cleaned up & refitted, along with pedal box back in car (no pics of that) and a heatshield made that replicates the original one
Built up
Built back up
#54
I bought a new motor for it Paul, I'm going to swap them over hopefully this winter & fit my Bara box at same time so I'll probably be in touch about the bulkhead material once I get the old engine out
#63
Monte 087
Monte 087
Was thinking of just getting the MO's I've got done silver for now, would love a set of 18" montes for it but got an engine to built etc first before I start thinking about wheels, I should have just bought some montes when they first came out
Brand new 3 bar
New power steering reservoir with powder coated bracket
Custom HEL brake line kit with banjo fittings for the AP's & slightly longer rears for the big brake kit
Brand new 3 bar
#68
Monte 087
Cheers, I never meant to take it this far it just sort of snowballed and I ended up stripping it to near enough a bare shell, only left the loom & dash in, kept on looking at it thinking 'fuck'
It's become an obsession now, have been collecting parts for years and have got lots of rare parts that are impossible to get hold of now, I'm on first name terms with the parts guys at my local dealers
