mk3 escort van resto
hi there just joined as will be hopefully restoring this van to it former glory
the van has been sitting for over 17 year owned by the same person for 20 years from what i can see it quit soild for a 30 + year old van
thanks for the good replys iv also for few more project mk2 transit spec lift and a vw mk1 golf 1.8turbo but would like to try and get it done for the new year if lucky need two floor pans and rear arches which ive just brought on ebay the seals and battery tray was replaced 15 year ago acording to last owner and still look good so ok there
the last owner told me it might have a 1.6 xr3 engine in but how can you tell the difference from 1.6 and a 1.3 also it has a 4 speed gearbox if that help
any help would be nice
i need to send off for logbook as they lost it but its down as a 1.3 was told it had a 1.6 xr3 engine fitted and it also has xr3 wheels but is there a way to tell
i remember driving a xreg escort van and that had a 1600 xr3 engine in it it flew some off the earlier vans had them
got all the repair panels now and have started cutting the passenger side floor pan out but have been thinking about getting an rs turbo engine but what do i need to make it fit and work
blimey savage sam a rare beast you have got their mate hope you give it a new lease of life and good luck with it mate I will be keeping a eye on this thread it definetly keep you out of trouble!!
thanks for all the good replys i have cut the floor pan out and have place the new panels in place till i can get some electric for the welder and have primed the front end plus replace the front lights
some more update on how the vans looking both floor pans are done and rear arches are done
this side was done but forgot to take picture
still alot to do but going to at least get one side done filled and primed
Hi, I am currently contemplating buying a mk3 van I know where there is one and had a look at it the other day. Like all vehicles its tired in certain areas and I am trying to decide if its worth getting.
It requires more welding than I would like for some reason O/S is rotten it also needs a new front end as it was in an light accident, the O/S floor pan needs replacing but my main concern is the O/S sill which I have never fitted (is this an epic)?
It also needs a O/S bottom rear panel (similar state to this van). Can you still buy these having looked around at various panel shops they all list hatch back only? do these fit are or they to short?
Do you feel I should buy this van or leave it alone and buy a mk4 and do a conversion I would prefer a mk3 any day. Any advice would be appreciated.
I went to look at the mk3 again but its a bit more rotten than I thought all the floor pans need replacing inner and outer sill are rotten there are holes down each side of the van where some clown has drilled into the side to attach shelves inside?
There are also holes in the roof where some one has drilled holes down the centre of the roof I would love to own the van but I think its out of my depth being a beginner at welding and I don't have the budget to pay any one to do it for me. I was going to attempt to put the front panel and wings on but rebuilding inner and outer sill and floor pan I think needs to be done properly.
Its strange the van looks solid underneath but when you look from the inside its rotting inside out?
To be honest I found a lot more rust then when I first brought mine and I have never seen another one in the last 5 year regarding the welding u are only going to learn by doing it also give your self twice if not three time the time to get it on the road
