Bit of an engine problem! Blocks apart
#163
cossie fan (unluckerly)
Sent my diff off to bara the other day. Would have re built it myself but there going to strip and paint it and fit an up rate kit so it went there. Building a little pile of bits now so I'll tow it to work soon and fit them all and get some pics up hopefully in the next month. Also secured an aero motive fuel pump off the rodders just got to go give him some money
#172
Nice collection of parts piling up there buddy
Cheers Paul
Cheers Paul
#177
it will be mate it's a slow process but im going over the car from bumper to bumper. I intend to not do any more work to this thing once it's back so its getting everything now. I'm really hoping it will be running July ish next year at the latest
#182
Looking good should be a monster mate what clutch will you be using?
#183
smiley (10-10-2015)
#185
Looking good.
#189
Coming on buddy!
Gonna be a monster this
Cheers Paul
Cheers Paul
#191
Its going to be a monster of a car when its done!
#194
Ran into a small issue this morning as you do with old fords. First time I've had the beam out in over 10 years o.s is solid but there is a hole in the n.s chassis leg. Luckily the mounting bolt point is still solid so could have been a lot worse so I'm happy. Monday I'll plate it and get the beam in
#195
Woah, not a great discovery but at least you are equipped to fix it.
#196
Great job your doing, the spec of your engine is the next step for me that I'm planning on doing soon.
The alternator, I take it your fitting one of marks twin scroll manifolds, just a drop bracket is not enough as the manifold catches the alternator. I milled the holes in the cast bracket that bolts to the alternator to lower it a couple of mill to clear, it's still very close, ideally u need the later 4x4 belt set up and tensioner that allows u to move the alternator away from the manifold.
