Twin 40's on a zetec
Old 16-09-2013, 01:24 PM
Rob90spec
Rob90spec's Avatar
Default Twin 40's on a zetec
Just throwing this out there at the mo to see if my understanding is right
I'm going to use a 2.0 zetec-junk the injection/inlet manifold in favor of some twin 40's.
Can I use my original gearbox off my 3i?
I know I'll need a efi flywheel and cps but how do I get that to the spark plugs at the right time?
Many thanks
Old 16-09-2013, 01:35 PM
SBT83
Not Crazy, just Unwell
SBT83's Avatar
Use aftermarket management GB should fit too
Old 16-09-2013, 01:42 PM
Mk4 Rick
Mk4 Rick's Avatar
Your gearbox will be fine.Have you ever thought about bike carbs?
Old 16-09-2013, 01:59 PM
Rob90spec
Rob90spec's Avatar
I hadn't thought of bike carbs but I wanted to mix old and new skool
My shopping list so far is
Engine-is it worth skimming the head to raise comp?
Twin 40's/pressure regulator
Adaptor plate for carbs
Cvh efi flywheel/cps
LSD for my 3i box
Aftermarket management
Am I missing anything major??
Old 16-09-2013, 02:02 PM
SBT83
SBT83's Avatar
Loom for management will need to be made, so wire
And shit loads of cable ties
Old 16-09-2013, 02:06 PM
Rob90spec
Rob90spec's Avatar
Ahhhhhh..........cable ties I can "borrow"
from work
Is aftermarket management expensive??
Do I have to chop up the engine mounts or
does a company make them?
Old 16-09-2013, 02:10 PM
rs clint
insane
rs clint's Avatar
from work
you can buy every thing to install a ztech
Old 16-09-2013, 02:13 PM
SBT83
SBT83's Avatar
from work
Management is around £500 upwards depending on make.
You can use different mounts from different fords to make the majority but I think 1 may need slight adaption. Someone on here should have on for sale. Or contact crazycage he'll make one up for you
Old 16-09-2013, 02:31 PM
Mk4 Rick
Mk4 Rick's Avatar
You can use esc to run bike carbs or nodiz.
Old 17-09-2013, 08:29 AM
Rob90spec
Rob90spec's Avatar
The more I look into it it doesn't seem to fraught with danger lol
I recon for about £1500 I'll get all the bits I need
Old 18-09-2013, 09:29 PM
escortmk3rwd
escortmk3rwd's Avatar
esc or edis4 off early mk3 fiesta mk5 escort non injection 2 wires back live brown earth thats the spark sorted done escort mk3 mk4 and fiesta mk2 zetec conversions for years got 1 on 45s mk2 fiesta on 40s and 100 bhp of nitrous bike carbs just as good had canny few with them on
Old 19-09-2013, 07:04 AM
hogdog
hogdog's Avatar
Webcon make an ignition kit specifically for the carb'd Zetec. It comes fully mapped and includes a wiring harness...£630.
www.webcon.co.uk
Old 19-09-2013, 07:12 AM
liam-rst
shit happens
liam-rst's Avatar
Good money that
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
sridgett
01-10-2015 07:30 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
Quick Reply: Twin 40's on a zetec
