Mk3.5 Fiesta Turbo Conversion Sleeper
Well i started this project approx 18 months ago when my marriage broke down, anyway this started out as a 1.3, and boy was it gutless, so i decided to build a sleeper, anyway here it is befre i started, its a very solid shell, just cosmetic rust, but will do the bodywork when funds allow it
The first thing to do was to remove the engine/box and engine wriring loom
Then the car was put outside while i found all the bits i needed, i sourced an engine, rebuilt that
Before i had a new cam i did a dummy build
Then i had to save for a new camshaft and followers, decided to get a newman one as heard to many horror stories of Kent ones wearing out in hardly any miles
Then had to dial it in
Mean while I had changed all the suspension, Gmax front shocks and Spax rears, and a set of lowering springs, powerflexed all the rear bushes, also changed the brakes to FRST ones, even changed the fuel tank and put in an uprated pump,
Then next was to rewire the engine bay, took me a little while but i got there, havent got any photos of that, then with the engine built i installed the engine and box
With the engine and box in, it was just a case of fitting everthing else in, had to modify the bumper to mount the intercooler
After moving it around work i noticed oil leaking out of the gearbox, then it dawned on me these boxes knock out diff bearings, put the car in the air and yep they were foobarbed, leaving it a while i then removed box and stripped it down, when i brought this box it aledgelly came from a working car, to my horror i found this
5 teeth missing out of 17, wasn't happy, anyway my local gearbox man saved the day, in his collection he had another crown wheel and pinion he had modified with a bigger bearing, and also this pair had a slightly different FD ratio, old one was 3.8:1, new one is 3.5:1 so a longer top end, after rebuilding the box with all new gasket and diff bearings and crown wheel and pinion it was refitted
with it all back together i tried t run it upto temp again, now it looks like i have a water problem, the water starts to rise as soon as i start the car, but no bubbles, even boiled up, then run out of fuel, that was a good reason to walk away as i have had to take at least a month off work due to an ankle operation, this is how the car stands at the moment (haven't even driven it on the road yet)
When i get back to work i will be getting on with it, god hopes i dont have to take the engine back out
Well it hought i had better update this as its been quite a while, well since i reaulit the gearbox i have had to take the engine back out and rebuild that with another block and head, as it had over heating issues i couldnt get to the bottom off. I managed to get hold of a ported and polished head and put new double valve springs in it, finally got it running again today after a year, no just got to get it bolted together and book it in with Jano and get it set up ready for the road
Ben
That will certainly raise a few eyebrows mate!
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
paceo
27-08-2015 12:45 PM
JoeyBoyden
18-08-2015 05:56 PM
