My 2litre MK4 fiesta
#526
Im looking at these bonnet catches £14.99 from hong kong
http://www.ebay.co.uk/itm/With-Key-B...item2c7f0d27d8
Then look at the mark up on these from the Uk
http://www.ebay.co.uk/itm/AEROCATCH-...item5644aebbcc
#532
I don't think they go well mixing mk5 front end with mk4 lol.Done some more digging behind the rear door kids.Ive found some more money a purple marker lol and ive removed some more sound proofing from behind the cards.The two black bags and the wooly material stuff
#540
What flywheel/clutch are you using? Tried fitting mine today and yesterday and ran into a problem I had the 1.8 flywheel and clutch and I was originally gna use the 1.8 gearbox but changed to 1.3 so the spline is smaller
#543
Not touched the car since sunday lol.Im gonna keep the mondeo rad and have it modified slightly so I can have one of these fitted .
http://www.ebay.co.uk/itm/2910895087...%3AMEBIDX%3AIT
#547
#550
Is the escort rs same as the fiesta rs clutch? Iv got a fiesta one for cheap to try tonight. But when I tried to mount the gearbox to the block with the 1.8 clutch in it was rubbing inside the bell housing? Maybe the 1.6 plate doesn't stick out so far or il just grind of the bits inside theb bellhousing lol
#551
Put the zetec clutch and frst clutch on the floor and make sure it's a bit slimmer.
Matt
#552
#553
Focus 1.8 clutch kit is the very same one for the focus 1.6! And there both 219mm and it fits within zetec-se ib5 bell hosuing.
#554
Na I started it on Sunday but the clutch Iv got [escort 1.8 zetec] doesn't fit in the 1.3 box and the hole in the friction plate is bigger than the pin coming out the gearbox. So had to wait til I can get a new clutch. Then it's just the case of the wiring
#556
1.6 focus 220mm
1.6 fiesta 210mm
1.6 puma 210mm
1.8 focus 220mm
1.6 fiesta and puma same price and part number
1.6 focus and 1.8 focus same price same part number.
Hence why Im ordering a 1.6/1.8 uprated clutch as there £90 cheaper than fiesta/puma 1.6 clutch
1.6 fiesta 210mm
1.6 puma 210mm
1.8 focus 220mm
#557
http://www.larkspeed.com/index.pl?a=...e-1-Clutch-Kit
focus 10mm bigger and £81 cheaper
alot of people forget the focus was the first car to have the 1.6 which is under rated as the 1.6 focus uses bigger clutch frp gear ratios. The fiesta and puma had smaller versions due to not needing it as there much lighter than the focus.
#558
Explain why my clutch and clamping plate have a bigger suface area than my 1.6 one then if its the same yet the guy above has the 1.8 clutch and he carnt fit it in his 1.3 gearbox yet I can?
#560
Fuck knows all I no is I had the 1.8 and the 1.6 nxt to each other and the 1.8 was meatier than the 1.6 because if it was the same I would have used the 1.6.But what do I no I only looked at both and fitted the engine
