1990 Ford Escort XR3i
Old 08-05-2013, 08:08 PM
GiugiaroFan
GiugiaroFan's Avatar
Default 1990 Ford Escort XR3i
Hey everyone!
I am currently trying to raise some funds in order to help restore/fix my mothers 1990 Ford Escort XR3i.
If you would like to find out more please click here.
GiugiaroFan is offline
Old 09-05-2013, 05:46 PM
RSmark84
RSmark84's Avatar
Is it wrong that i just laughed at this thread, and the link?
RSmark84 is offline
Old 09-05-2013, 05:58 PM
mattxr3i
mattxr3i's Avatar
Nope, I did the same
mattxr3i is offline
Old 09-05-2013, 06:28 PM
RSmark84
RSmark84's Avatar
Glad im not the only one. I shall return regularly to see how the 'donations' come along.
RSmark84 is offline
Old 09-05-2013, 08:01 PM
karl mcghee
karl mcghee's Avatar
Still no funds then lol
karl mcghee is offline
Old 09-05-2013, 10:13 PM
escortmk3rwd
escortmk3rwd's Avatar
give you 250.00 for it
escortmk3rwd is offline
Old 10-05-2013, 02:07 PM
steve st220
"SNIFF MY DIFF"
steve st220's Avatar
PMSL.. she only bought it last year!!
Jobs that need to be done
Listed below are parts that need replacing or jobs that need to be done on the car.
•Fuel tank is dented, leaks and the fuel sender unit has stopped working. To fix these problems, the whole fuel tank needs replacing.
•The tracking may need to be sorted.
•The front anti-roll bar has broken, so this needs replacing. Bushes have also split.
•The gearbox is leaking fluid at an alarming rate, worst case senario is that the car will need a new gearbox.
•Exhaust silencer is cracked and blowing also the exhaust mounting have perished.
•There is a slight knock and too much play in the steering rack.
•Both outer driveshaft gaitors are perished.
•Bottom of drivers-side door is corroded.
•Rear trailing arm bushes have perished.
•Nearside front brake hose is starting to split.
•Rear traling arm bushes have perished.
•Plus a few other jobs which we are in the middle of dealing with.
£1500 to fix, get a job and fix it then like everyone else.
steve st220 is offline
Old 10-05-2013, 06:13 PM
RSmark84
RSmark84's Avatar
the list alone is only a few hundred pound worth of work.... not sure where the qoute of £1500 came from really...?
RSmark84 is offline
Old 10-05-2013, 06:20 PM
escortmk3rwd
its an old knacka
Old 10-05-2013, 09:34 PM
GiugiaroFan
The quote came from a local garage and is taking into account all of the possible worst case scenarios.
Old 11-05-2013, 05:41 AM
Fordmad!
Fordmad!'s Avatar
don't mean to be harsh but i think your dreaming nobody in their right mind will donate any money for this
Fordmad! is offline
Old 11-05-2013, 06:40 AM
AJC
AJC's Avatar
As above, sorry pal but your on your own.
And £1500 to fix is ridiculous, for £1500 ill come collect it, fix it, MOT it.
And deliver it back to you.
AJC is offline
Old 11-05-2013, 03:51 PM
RSmark84
RSmark84's Avatar
They are pulling the cover over your eyes!
No way is that £1,500 to fix. the bushes are a couple of quid each as is the brake hose and the CV boots/gaitors.... Thats half of the project done.
I'm sure a steering rack is about £30 of ebay.
The other bits can be had from breakers on ebay, theres plenty of XRs being broken on there. I reckon £300 in parts alone. So they are charging you £1,200 in labour.
Find another garage or do 75% of the work yourself a novice can do that stuff. The tracking a garage will do, at the same time fit the steering rack and fit the gearbox.
The garage may be able to weld a new exhaust mount(if its on the chassis) or it'll be replaced with the new exhaust you'll be buying.
Post a pic of the rotten door, it may need a little bit of welding or again replaced from a breaker. If the door has to be replaced it'll be about £100-£200 cash job for a respray.
RSmark84 is offline
matman
09-09-2015 05:45 PM
dodge8283
27
19-08-2015 08:42 AM
Bloody-Fox
03-08-2015 07:48 PM
Quick Reply: 1990 Ford Escort XR3i
