RS 5tu S2 RS Turbo Project, BBS E50 content :)
Old 05-05-2013, 09:42 AM
RS 5tu
RS 5tu's Avatar
Default RS 5tu S2 RS Turbo Project, BBS E50 content :)
Ive gone and got my self another RS, plans so far are EFI conversion with OFAM ecu and 1.6 cvh with steel rods and modest power and just to have a clean usable car.
Old 05-05-2013, 09:45 AM
H7 CYA
H7 CYA's Avatar
Looks tidy mate, was this on eBay? Look forward to the progress
Old 05-05-2013, 09:46 AM
RS 5tu
RS 5tu's Avatar
Yeh was on ebay about a week back.
Old 05-05-2013, 09:47 AM
GINGExR2 T
GINGExR2 T's Avatar
That looks very clean, what wheels are they mate, been looking at something simular for my car.
Ginger
Old 05-05-2013, 09:48 AM
RS 5tu
RS 5tu's Avatar
Ginger
They are cades eros i think.
Old 05-05-2013, 10:31 AM
Need more pics.I like the wheels.
Old 05-05-2013, 10:58 AM
RS 5tu
RS 5tu's Avatar
Old 06-05-2013, 09:57 PM
GINGExR2 T
GINGExR2 T's Avatar
That's the ones I was looking at on Ebay, can't find anything bigger than a 16x7j though, really nice wheel, really suit the car.
Ginger
Old 06-05-2013, 10:09 PM
RS16iDale
RS16iDale's Avatar
Yea agree wheels look smart
Old 06-05-2013, 10:28 PM
bigryrs
RSHoleinator
bigryrs's Avatar
Really like the look of that mate! good luck with it
Old 07-05-2013, 06:17 PM
RS 5tu
RS 5tu's Avatar
i like the wheels i wasnt sure at first and was thinking of getting some compomotives but wanted to be alittle different so think ill be keeping them on for now.
Old 07-05-2013, 07:44 PM
jonny s2
jonny s2's Avatar
great plans, dont let it go outta controooooolll
looks a nice car!
Old 08-05-2013, 04:14 PM
RS 5tu
RS 5tu's Avatar
These turned up today,
My plan is to strip my engine this weekend and get the block honed and crank checked
Then I'll buy all the bearings ect once I know everything is ok.
Old 12-05-2013, 07:30 PM
RS 5tu
RS 5tu's Avatar
Started the strip down today, bottom end and gear box is ready to come out tomorrow then the engine is going to get stripped and inspected to see whats needed before rebuilding.
Old 14-05-2013, 07:11 PM
RS 5tu
RS 5tu's Avatar
My MS based OFAM ECU turned up thanks to boostmonkeys, carnt wait to get it all back out on the raod hope it dont take to long although the todo list is growing by the day.
Old 15-05-2013, 06:43 PM
ryan_gwa
ryan_gwa's Avatar
Is OFAM converted from OFAC or OFAB?
Old 15-05-2013, 08:09 PM
RS 5tu
RS 5tu's Avatar
None, its a Megasquirt 2 based ecu thats been modified to fit in the standard case and use the standard plug.
Basically a MS2 plug and play ECU for ford EEC IV, ideal for me none of the wiring to do
Old 16-05-2013, 07:10 PM
H7 CYA
H7 CYA's Avatar
^^^ that sounds pretty cool. Looking forward to seeing how you get on with this. You just running frst inlet, wiring tab etc.....
Old 16-05-2013, 08:03 PM
RS 5tu
RS 5tu's Avatar
I plan on getting most of my bits from a EFI xr3i i have, loom, head, inlet, flywheel ect ect the ECU will PnP into the 3i loom most of the build time will be checking and cleaning bits before putting it all back in.
Old 09-06-2013, 06:15 PM
RS 5tu
RS 5tu's Avatar
Not much happening with this at the moment as i dont have that much free time, at the moment im just waiting on time to get a new battery tray fitted and tidy the floor pans up and there is a few holes but nothing to major.
where its at now.
Old 09-06-2013, 06:21 PM
RS 5tu
RS 5tu's Avatar
Engine wise ive come to a bit of a stop, unless i can get a 2nd hand decent forged engine im just going to rebuild my 1600 as i wasnt looking for anything special power wise around 250 would have done but dont fancy spending 1k+ on just a bottom end at the moment as i am not sure if thats what i want from the car i would rarther have a nice clean car i can use and less power.
i cleaned my pistons and rods up so they could be checked for cracks and there fine amazing how clean they come up with the right equipment.
Old 09-06-2013, 06:43 PM
Rob_DOHC
Rob_DOHC's Avatar
Looks like a really smart base for your project mate, best of luck with it
Old 09-06-2013, 07:15 PM
RS 5tu
RS 5tu's Avatar
Thanks Rob, ill be a happy man when its back out on the road
just need to keep things in check and not get carried away.
Old 09-06-2013, 07:26 PM
Rob_DOHC
Rob_DOHC's Avatar
Hahah, not getting carried away is the really hard part
Old 09-06-2013, 08:23 PM
Ben26
Ben26's Avatar
could be a cheap option
http://www.ebay.co.uk/itm/Escort-Fie...item3a81ea4633
Old 09-06-2013, 08:27 PM
RS 5tu
RS 5tu's Avatar
Originally Posted by Ben26
indeed, think ill be bidding on them thx ben
Old 10-06-2013, 09:18 AM
0150carmac
0150carmac's Avatar
looks like you bagged yourself a good one
Old 11-06-2013, 09:48 PM
rsmark86
rsmark86's Avatar
sounds like a cool project mate keep the updates coming
the williams steel rods seem good too mate, simsytall on here ran them at 24/25psi on a stage 3 t3 and 5th injector with no problems
Old 12-06-2013, 08:02 PM
RS 5tu
RS 5tu's Avatar
The williams steel rods seem good too mate, simsytall on here ran them at 24/25psi on a stage 3 t3 and 5th injector with no problems
Yeh imo there a good quality there seem to be alot of these rods about all be it will a different name on them and havent heard a bad thing yet.
What power did simsytall make?
My next thing on my to do list is sort the battery tray out in the car as it needs a new one. Engine wise im just waiting on a bottom end really but carnt make my mind up at the moment but pretty sure im going to stick with CVH and got my head back from the machine shop today it was getting skimmed.
So far i have got as far as:
Ofam ecu
Ported and polished EFI head with bigger valves, bronze guides and double valve springs.
Cossie T3 rebuilt with 360 bearing
next few weeks
bottom end will be a fully rebuilt CVH with forged pistons and rods HD bearings and high preasure oil pump.
need to sort a cam and some injectors and then tidy and check my loom.
no idea what power i will end up with but i would be happy with a few less horse power and alittle more reliability
Old 12-06-2013, 08:15 PM
rhinopower
rhinopower's Avatar
Its only 3 pistons?
Old 12-06-2013, 08:29 PM
studabear
studabear's Avatar
I've a set of focus rs mk1 injectors if any use to you, I live in blackpool too.
Ł20 if you want them.
be nice to see another rs turbo out and about in blackpool, I remember back in the day when it was a everyday site.
Old 13-06-2013, 07:35 PM
Gem frst
Gem frst's Avatar
looks good this
Old 13-06-2013, 07:37 PM
martinmilne
martinmilne's Avatar
another black boost monkey rst good luck with the rebuild
Old 15-06-2013, 02:06 PM
RS 5tu
RS 5tu's Avatar
Thanks for the comments,
I should be in a position to take my engine to AMS for building in the next two weeks.
Ill feel better about it when it's just back on the ground rolling around and not on axel stands gathering dust.
Old 15-06-2013, 02:16 PM
RS 5tu
RS 5tu's Avatar
Ive sent you a in box message.
What impedance do they run at out of interest?
Old 15-06-2013, 02:21 PM
ClassicFord94
ClassicFord94's Avatar
Loving the wheels mate. Looks like a nice clean & tidy car mate.. Cannot wait for the progress and the finished piece.Spot on mate.
Old 23-06-2013, 06:25 PM
RS 5tu
RS 5tu's Avatar
Engine sorted now,
Stage 3 head with matching ported inlet manifold and focus RS injectors
CVH with Accralite pistons and h beam rods all rebuilt ready to go
Just need to tidy the shell now and buy a few more bits.
Old 23-06-2013, 07:45 PM
xr2imetalhead
xr2imetalhead's Avatar
that looks smart mate and the wheels look perfect on it too good luck with it dude!
Old 24-06-2013, 07:49 PM
Rsturbo james
its all good
Rsturbo james's Avatar
good project mate
ill be watching this
Old 24-06-2013, 08:26 PM
RS 5tu
RS 5tu's Avatar
Thx, its time at the moment thats the hold up i just done have any free with work and traveling.
Next on the slightly smaller "to do" list
Full polly bush set powder coated bits, and then sort a gearbox out and paint the engine bay also toying with the idea of putting in a different set or recaros i have from a Proton GTI but not sure yet, ill dig a picture out.
Quick Reply: RS 5tu S2 RS Turbo Project, BBS E50 content :)
