Ford Mondeo Folkrace car (Swedish budget rallycross) *New seat in*
Firefighter
Finally i got started on my folkrace car. Its a Mondeo 2,0l 1994 estate.
Current status is that i got it running after almost 2 years of just standning there. Not much to do. Just some jump cables and it fired right up
Some cleaning in the engine bay. The was a mouse nest and the had fed on the ingition cables
From the front seats and back its all cleaned out at the moment.
Will get some pictures up.
The list of things that should be done:
Remove all lights
Remove all of interior and fit the cage
Remove airbag
Decat and new exhaust
6 point harness and FIA approved seat
All windows exept the front window changed to plastic.
Anybody know a good way to disable the alarm system. Should i remove all of its compoments?
Loads of more stuff to be done.
Here you can read about Folkrace
http://en.wikipedia.org/wiki/Folkrace
Remove all lights
Remove airbag
Firefighter
Passenger seat is out
Backdoors are stripped from panels
Next up is front passenger door. The drivers side must be covered with panels or a sheet of metal. (Safety issue)
Sorting out what wires i don't need and the fuel tank must be removed and replaced by a small one (max 12 liters)
The window mechanism will also be removed for weight. Not much but every piece matters in this project I don't feel to put all the money in the engine
The soundisolation is also going to be stripped out
Firefighter
Forgot to take some pictures but this has happend since the last update:
Started to remove the wiring loom from the back
The passenger door card, speaker and isolation is removed
Most of the dash is removed
When the dash is out the car is going away and get the cage welded in
Rear view mirrors on the doors is removed
Glassbreak sensors and loom is removed from the B-pillars
Open airfilter mounted
Some other bits i don't remember
Today i will pick up my lovely doughters so this project comes to a halt for a week now.
Resident Wrestling Legend
i found that when i removed loads of stuff from my car, the suspension went a bit funny, especially when i was braking, as the weight that it was designed to have in it wasn't there and so it was either stopping sooner at one end or it was laying down the rubber better at the other
just some advice in case you end up swapping ends more often than you expected to when you are out and about
Firefighter
I think its gonna be heavy as iam going for the full spec cage. There is a minimum spec that must be mounted but im going for higer spec one
Firefighter
Yes that is the greatest part of all. Anyone can enter regardles of budget.
Its not cheap to build a car from the ground up but iam taking this as a slow project and learn something along the way, its mabye will be ready in 2014 . its the first time i bulid my own. In the past i just helped friends with finished cars.
Minimum spec cage looks like this:
I am thinking of adding these on both doors instead of just one pipe
And have an "X" in the roof aswell. It happens sometimes that the cars roll over. I think there was 6 cars last race that rolled over.
*** Sierra RS Custard ***
Crossbrace on the drivers door definately is a good idea, I dont think the others will be required though, but it depends on how many times you intend to roll it I guess.
Can certainly see the logic in adding more if its likely to go on its roof a few times during its career.
Firefighter
Firefighter
Firefighter
Firefighter
Thanks first time iam building a car from scratch. I have only been mechanic for my friends before this
The mazda didnt won it just got back in the race its quite common that cars that roll or crasch always try to finish the race
Firefighter
Firefighter
Firefighter
ive built a few rollcages for dirt track racing (in holland called autocross), and i can get you a few tips. the tube from the a pillar to the b pillar, get one in the middle, but dont get it on the floor , just stop where the b pillar goes from left to right and weld it on that tube. if you are taller, weld a plate on top of the cage instead of a cross. get a cross welded behind your seat (dunno if you need to get your seat fixed to the rollcage, but whe had to, so, starting from the x between the b pillars is a very solid start. also, make sure you've got a pipe laying on the doorsill, just below where the x is drawn here, makes your cage a lot stronger. cross between the last legs wont help much, use a single tube on the last piece, and maybe to cheat the rules a bit, make the c pillar tubing end almost on top of your shocks, and you can fix your shocks to the rollcage. wheve don the same at the front, and the car went on and on and on and on, for 6 seasons iirc, while much of the other cars did one or maximum two seasons.
i like the idea of the races you have, overhere there are getting way to many rules (even sound regulations), so time for another class!
Firefighter
Thanks for the input!
I will have a look at this. Iam not building the cage by my self its a friend that has welded a lot of cages both for folkrace, rallycross and rally cars. I will also add reinforcment to the passenger side. Not required but idon't want that side to be unprotected. We have sound regulations as well. Max 100 dB
Pic from yesterday dry fitting the hood latch kit
And mounted :
And mounted :
yeah, being good protected was our number one concearn, nice to get racing on sundays, but monday is a working day!
our cage was inspired by this little one
but, whe didnt have the plates welded on, and whe used two pipes in the door instead of 3, but the outer pipes went all the way to the door skin, so you had a few extra inches for your arm. this picture is a nascar rollcage, a bit stronger than ours was, but you'll get the idea, see if you can hang your engine on the cage to, dont know if your allowed to, and if it's a contact class (not the shy oh boy i'm scared so i'll hit you softly contact, but full contact), but you might want to use solid steel motor and gearbox mounts also, you dont want to loose your engine after a rollover, if in full steel mounts, it's just start her up, and go again, see if you can get to the finish and score those few points you might need to hit the finals...
Firefighter
Engine should be in the original mounts. But soild mounts is a good idea. The cage must not go past the front wheels. There are restrictions on how its being built. The car should be as factory stock as possible. Its a budget class racing so the cost of each car should be keept at minimum
Firefighter
Carbon Crazy
Just be aware your 2 pin cut off switch doesnt have a alternator drain down or ignition cut off.
If you connect it to battery, your engine will run on when isolated, if you put the alternator lead on battery side of switch, you will likely blow up your alternator when you isolate it.
A lot dont realise that. I shocked my mate by cutting his isolator with the engine on and the look on his face when it stayed running was priceless.
Firefighter
Firefighter
Yesterday was a bad day
Cutted some pipes to the AC and the result of that was that all the oil from the compressor ended up on and around the engine but after a good wipe the engine is kind of clean. And i will remove the compressor anyway.
Next problem was that I cutted the wrong thottle cable. I was going to cut the one to the cruise control but not thinking enough and a bit stressed becourse i was running late for Krav Maga class i cutted the main throttle cable.
So i just closed the hood, got a machine and pulled it out of the workshop, now I will rest from this project a few days
Firefighter
Small update:
FIA approved seats
Its only allowed to have one seat in the car but i got a bargin at 150 quid for both. Was used in a rallycar that only ran 4 races.
I will probably make a stand so i can fit the extra seat in the passenger side in case iam using the car on track outside competition
The belt is just for testdrivning (not FIA approved) i will race with a 6 point belt
FIA approved seats
Firefighter
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
