Mk3 escort zetec turbo sleeper (engine bay painted 24/8/14)
Old 11-05-2013, 03:45 PM
  #41
mothrs2k
mothrs2k's Avatar
Good base to start with
Will be watching this!
Good luck
Old 11-05-2013, 05:53 PM
  #42
RS16iDale
RS16iDale's Avatar
Cheers mate
Mark iv sent you a pm about the the mtx bits
Old 12-05-2013, 08:00 AM
  #43
rsmark86
rsmark86's Avatar
It will finish off your project nicely
Old 16-05-2013, 11:43 PM
  #44
RS16iDale
RS16iDale's Avatar
Not updated for a while but been busy in the garage tonight building up the engine,The focus rs pistons and rods are in,all valves lapped with new stem seals,focus rs head gasket,focus rs cams took a while swapping the shims about to get the right clearnce but got there in the end.
Also fitted the focus rs oil feed adaptor.will sort out few gaskets and the rest can be built up.
Old 17-05-2013, 04:40 AM
  #45
Cool project.There car looks like a good one.
Old 23-05-2013, 10:04 PM
  #46
RS16iDale
RS16iDale's Avatar
Only small update because been busy with work change and waiting on parts.
One piece of my puzzle that has turnt up though is my mounts.
Mr crazycage has done a spot on job with them so very happy.
Taking the car to a friends workshop 2nd weekend of june to do a few weld repairs so once their done then updates should be fairly regular.
Also had the pleasure of working on this beast lately,it was my friends dad who sadly passed away at start of the year.car was left to him nd his brother.got it fixed up as its been sat for few years and we took it to a local classic car show at the weekend.
Old 23-05-2013, 10:19 PM
  #47
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
:O nice! Wondered how long it would take for a set of my bearings to arrive on PF Project looks nice so far! Keep the updates coming
Old 23-05-2013, 11:17 PM
  #48
RS16iDale
RS16iDale's Avatar
Was it you that i was talking to through ebay?
Old 24-05-2013, 12:06 AM
  #49
Turbo Zetec
Engine Machinist
Yup indeed
Old 24-05-2013, 07:40 AM
  #50
RS16iDale
RS16iDale's Avatar
Ah ok small world.thank you very much again for sorting them out
Old 24-05-2013, 12:32 PM
  #51
oriurbo
oriurbo's Avatar
Love the car mate.
What are you gonna do body wise are you gonna keep it looking sleeper ?
Old 24-05-2013, 02:52 PM
  #52
RS16iDale
RS16iDale's Avatar
Cheers mate,body is staying how it is,will just sit lower on mondeo steels thats about it,will have full interior
Old 24-05-2013, 02:58 PM
  #53
oriurbo
oriurbo's Avatar
Glad to hear it .
Old 27-05-2013, 10:28 PM
  #54
RS16iDale
RS16iDale's Avatar
Managed to do a bit this weekend,Got the car jacked up and all the front suspension,anti roll bar and brakes off.New suspension is on its way and poly bushes,got cossie 4pots to go on aswell.
Engine would of been done but had a mess up on my parts,but have been able to fit my arp rod bolts,upper sump,lower sump.Got my inlet manifold now aswell
Old 29-05-2013, 10:04 AM
  #55
RS16iDale
RS16iDale's Avatar
Had a my helper in the garage last night,finaly got last few bits so engine is now built.
Inlet is only on there temp at the mo,got to take it off to have a lil think about fuel rail.
Just got my turbo gaskets,stud and nut kit through post today,so can trial fit that on this week.still need to get new actuator bracket because ive spun the inlet side round 180degrees to reduce inter cooler pipe work
Old 29-05-2013, 11:13 PM
  #56
RS16iDale
RS16iDale's Avatar
How do you edit the thread title?
Old 30-05-2013, 12:12 PM
  #57
drsrst2zvh
drsrst2zvh's Avatar
Go to your first post when you started the thread and at the bottom there is a little box that says "edit" then click "go advanced" then you can edit the title.
Old 30-05-2013, 12:31 PM
  #58
RS16iDale
RS16iDale's Avatar
Cheers mate
Old 30-05-2013, 12:52 PM
  #59
Jamie@FastFord
Jamie @ Fast Ford
Jamie@FastFord's Avatar
Cool looking project - keep us updated
  #60
rhinopower
rhinopower's Avatar
You know that focus rs cams are exactly the same as normal 2.0 cams? I've built the same engine funnily enough
Old 30-05-2013, 04:57 PM
  #61
RS16iDale
RS16iDale's Avatar
Wasnt sure lol,but their only my old ones anywayz
Old 01-06-2013, 10:27 PM
  #62
RS16iDale
RS16iDale's Avatar
Got busy with the grinder this evening.
Spare wheel well out ready for flat floor.
Front panel cut out for intercooler,may need to cut the upper part though.
And cut out the gearstick hole and made the plate ready to weld in.
Old 02-06-2013, 04:35 PM
  #63
ntlsurfer
ntlsurfer's Avatar
looking good , very interesting thread
Old 02-06-2013, 06:41 PM
  #64
RS16iDale
RS16iDale's Avatar
Cheers mate,its all good fun
Old 10-06-2013, 06:56 PM
  #65
RS16iDale
RS16iDale's Avatar
Not much of a update to be honest but i have removed the old leaking fuel tank
Painted anti roll bar and brackets,fitted polybushes and the ones on steering rack.These will all have to be removed again when i underseal the underneath
Also gave one one of the wings a quick polish to see if the flat paint can be restored,looks like it will come up well enough
Old 10-06-2013, 08:23 PM
  #66
The wing has come up well.Have you got any more pics of the ford hot rod.
Old 10-06-2013, 09:42 PM
  #67
RS16iDale
RS16iDale's Avatar
Ill get some mate,its cool but needs some work
Old 12-06-2013, 05:16 PM
  #68
Dennis_Wiseman
Dennis_Wiseman's Avatar
Cracking find in that condition. Don't be tempted to stick buckets and a cage in though mate lol Mk3 Escorts look the nuts as base specs. Keep it as standard as possible imo
Look forward to seeing the updates.
Old 12-06-2013, 05:35 PM
  #69
coming along nicely
Old 20-06-2013, 07:27 PM
  #70
smoothy rs
smoothy rs's Avatar
Hi there can I ask what turbo you are going to use as im building a mk6 escort van and wanted to use the focus manifold cheers
Old 22-06-2013, 08:43 AM
  #71
JezST3
JezST3's Avatar
loving this build keep up the top work
Old 23-06-2013, 09:29 AM
  #72
luke19790_3
luke19790_3's Avatar
Looking good, Anymore pics?
Old 23-06-2013, 01:32 PM
  #73
MrCapriScort
Old Fords Never Die
MrCapriScort's Avatar
Great project, need more pics
Old 23-06-2013, 01:37 PM
  #74
Ben26
Ben26's Avatar
l Wanna'keep my eye on this one
Looks intresting
Old 23-06-2013, 07:45 PM
  #75
gjh
gjh's Avatar
Looks good. Love the old hot rod further up the page too.
Old 23-06-2013, 10:12 PM
  #76
RS16iDale
RS16iDale's Avatar
Sorry for the lack of updates guys,if im honest havnt done anything exciting on the car apart from some welding.but been collecting few parts.
Dennis wiseman- dont worry mate its staying standard looking with full interior.
Smoothy rs- its a standard focus rs turbo gt25
Old 23-06-2013, 10:58 PM
  #77
ram
Has a large member
ram's Avatar
wicked project
Old 15-08-2013, 10:29 PM
  #78
RS16iDale
RS16iDale's Avatar
Been a long time since i updated but havnt really done much since. Ive had various things happning recently but i finaly got the car over to my mate ready for welding (only 2months late)
Dropped it off last week and then popped there last night to see whats what.hes got the car mounted on the spit now,found a couple of lil areas to fix nothing major so happy about that.
While i was there i stripped all the suspension off and brought it back home.
All stripped
Old 15-08-2013, 10:32 PM
  #79
RS16iDale
RS16iDale's Avatar
While its there its going to be fully welded,all undersealed,new fuel lines,new brake lines,new suspension,fully polybushed and then engine and gearbox mounts welded in.
So when i get it home shouldnt be to long to complete
Old 16-08-2013, 12:23 PM
  #80
0150carmac
0150carmac's Avatar
thats going to be nuts when it finished
look forward to seeing the finished article
Quick Reply: Mk3 escort zetec turbo sleeper (engine bay painted 24/8/14)
