Zetec turbo escort. Nearly there...
#42
When did the car change hands mate lol.Its a belting motor and I hope it gets finished off
#46
Painted the roll cage, new perspex front windows with sliders, had strut braces powder coated, New powder coated header tank, rocker cover powder coated, New Brake disc's & pads all round, Devil developments custom cams, fresh mobil 1 oil and loads more bits
#47
Fair play for taking it on, did try to persuade Tom to stick at it n keep her but glad shes moved onto another good home...will keep an eye on this
#48
After ringing approx ten company's in the south of the uk to get quotes for my custom exhaust, I found 'Edwards motorsport' by luck on a mk1 escort page and luckily for me he was 10 miles away from where i live. The cheapest quote i had for a full 3" stainless custom system was Ł950 (plus vat). This was for a full system turbo back with external wastegate plumbed back into the downpipe, two silencers (for track use) with a 3" outward rolled tip.
Edwards motorsport made me the full exhaust system to the above spec, made a custom rear gearbox mount for focus rs gearbox and 2 custom made alloy boost hoses for Ł950 cash ! And his work is second to none !
here are some pic's
well happy with the work !
here are some pic's
#54
If you decide to uprate the oil pump, there is a kit sold by Burton power that I have seen working on a na zetec with 260 bhp that reved to just over 8k, may be worth a look
#59
Hello mate to fit the focus rs gearbox do you have to cut out the inner chassis leg for it to fit? Im using the crazy cage mount same as you but its mounted to a blacktop zetec and going in a mk3 escort,just dosnt fit at the mo?
#61
Had these tails welded onto the sump today and fitted sump back on. One tail is for the oil return from the turbo, the other is for the oil drain from the oil seperator. Also ordered one of these for the crankcase breather thanks to 'Will Pedley'
https://passionford.com/forum/trader...breathers.html
#68
#71
Hi mate looking good.These items for the return would have worked with no welding at all.Either way your car is looking really good.
http://www.ebay.co.uk/itm/1110675518...84.m1438.l2649
#74
be careful with the level of your oil returns mate as said above, especially if you're running a gt series turbo.
you might be fine, just dont like thinking of a smokey turbo after all your work.
#80
Just a quick update i have had the head off and crazycage has ported the exhaust side for me. He also has made me a turbo hanger and is currently making me an inlet manifold. Fitted the head back on today. Got all the new fuel hose/lift pump etc to finish fuel system so will have more updates over the next few weeks.
